Why I Want A Holden And Being Ghey Is Okay!
"Captain Retard"
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 6d
Yeh that's kind of what I was getting at VCM have sooo many to pick from and for diff applications but then once only tied in with other mods
How did u find the cam install ? Bit of a decent process, did u dial it in ?
  • Member For: 11y 10m 3d
Yea, once I open up a few motors and get some measurements of the valves, chamber, flow the heads/manifold and stuff I'll be able to make a better judgement on a cam choice...
Unfortunately I didn't have time to do this install, so he got a "family friend" to do it, big mistake!! He didn't change the timing chain so in turn didn't dial the cam in as you use the crank gear to dial it in... Just adds to me not trusting anyone to complete tasks for me
Same old story hey, want something done do it your self
By what I understand the stock valve drive system needs replacing when doing a cam as the stock stuff just is not up to the task !!
The cam I may hold off on as unsure what path the donkey will go down in regards to boost or N/A
From what I've heard the stock stuff is actually pretty good, and you can do it all at the same time as a cam swap, except for the lifters, the heads need to come off for that and they recommend to replace with GM performance ones if it has done more then about 80k kms, but that's just what I have found from my research so far
https://vimeo.com/111799905
It's no turbo falcon, and hasn't had its final tune but he gave it a good go... I actually believe the rear brakes are holding it back quite abit, so a line locker kit will be next on the list =)
Edit: he's feathering the throttle, and he dumped it in second
Edited by Peppy_t92
  • Member For: 17y 2m 13d
Nice private road I hope, CTO 06T
  • Like 2
Guest
This topic is now closed to further replies.
