rollex Member 683 Member For: 11y 12d Gender: Male Location: Australia Posted 11/10/14 06:00 AM Share Posted 11/10/14 06:00 AM (edited) So I installed my process west stage 2 kit today and when tightening up the new bracket the torx nut I suspect has cracked inside somewhere, it wasn't completely loose but I didn't want to remove it as it still feels like it is holding the piping in reasonably securely.Does this just hold the timing cover on or does it also seal the timing cover against the head? will this mean my timing cover will start to leak oil eventually?As this is an alloy head can I just get a mobile helicoil guy to come and drill it out and replace, or is it simply just to hold the cover on and nothing to worry about? Edited 11/10/14 06:01 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/89370-cracked-torx-nut-on-timing-coverrocker-cover-is-this-a-serious-issue/ Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 1m 26d Gender: Male Location: ACT Posted 11/10/14 09:48 PM Share Posted 11/10/14 09:48 PM Re ... " the torx nut "Its a bolt ! What you could do is... try to take it out and put some Threat Tape around the threat... That may give it some more/better grip. Link to comment https://www.fordxr6turbo.com/forum/topic/89370-cracked-torx-nut-on-timing-coverrocker-cover-is-this-a-serious-issue/#findComment-1505532 Share on other sites More sharing options...
willo88 Member 700 Member For: 13y 4m 26d Gender: Male Location: Newcastle Posted 11/10/14 10:14 PM Share Posted 11/10/14 10:14 PM Same thing happened to mine on the other side. It's a bolt for the timing cover and you would have pulled the thread out of it. Not the end of the world as mine hasn't leaked for over 2 years Link to comment https://www.fordxr6turbo.com/forum/topic/89370-cracked-torx-nut-on-timing-coverrocker-cover-is-this-a-serious-issue/#findComment-1505534 Share on other sites More sharing options...
rollex Member 683 Member For: 11y 12d Gender: Male Location: Australia Posted 12/10/14 12:28 AM Author Share Posted 12/10/14 12:28 AM Found someone on ford forums who had a tap made up for it and is also in Adelaide, will borrow it and get captain thread to redo it. Sounds like it is fairly common to strip these, like 5 guys who have said they have also done it. Link to comment https://www.fordxr6turbo.com/forum/topic/89370-cracked-torx-nut-on-timing-coverrocker-cover-is-this-a-serious-issue/#findComment-1505562 Share on other sites More sharing options...
