maxmundy Member 16 Member For: 10y 2m 5d Posted 06/10/14 01:28 PM Share Posted 06/10/14 01:28 PM Hello, I've recently bought an XR6T and occasionally when I start it up it will hardly idle for 2 seconds then die prompting a red hand flashing on the dash, occasionally the heaters/all aircon will be disabled also? And after it dies it won't let me start it until after about 5 minutes, it just slightly clicks when I try and turn it over then nothing happens, it doesn't even try turn over.It is very frustrating it happens almost every morning!Thanks Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 17d Gender: Male Location: Probably above atmospheric pressure Posted 06/10/14 02:21 PM Share Posted 06/10/14 02:21 PM Does it crank fine? Borrow a battery and see if that helps would be the first thing I'd do, they play up in strange ways with bad voltage. Seemingly unrelated stuff like speedo suddenly dropping to zero, for example.Even if it cranks fine I'd still try another battery as it's fairly quick. Link to comment Share on other sites More sharing options...
maxmundy Member 16 Member For: 10y 2m 5d Posted 06/10/14 10:54 PM Author Share Posted 06/10/14 10:54 PM Okay thank you Stever. Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 3m 23d Gender: Male Location: Zombie Birdhouse Posted 06/10/14 10:57 PM Share Posted 06/10/14 10:57 PM what he said . let us know how it goesbtw welcome Link to comment Share on other sites More sharing options...
maxmundy Member 16 Member For: 10y 2m 5d Posted 06/10/14 11:35 PM Author Share Posted 06/10/14 11:35 PM Okay so what will happen, I go to start it in the morning, it will start up, and 2 seconds later it will stall pretty much instantly.I then try to start it again, after turning the key all the way it just has a few light clicks, it doesn't try to turn over.After it has died it also comes up with a little hand icon in the dash flashing and occasionally the aircon and lots of other electrics will stop working. It's so frustrating, I will replace the battery ASAP. Thanks guys. Link to comment Share on other sites More sharing options...
maxmundy Member 16 Member For: 10y 2m 5d Posted 06/10/14 11:36 PM Author Share Posted 06/10/14 11:36 PM If it isn't the battery, any other suggestions? Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 17d Gender: Male Location: Probably above atmospheric pressure Posted 07/10/14 12:05 AM Share Posted 07/10/14 12:05 AM Try to avoid buying a battery as I'm only taking shots in the dark here. Borrowing one would be the go if you can. Link to comment Share on other sites More sharing options...
maxmundy Member 16 Member For: 10y 2m 5d Posted 07/10/14 12:10 AM Author Share Posted 07/10/14 12:10 AM Yeah I will give it a try, thanks! Link to comment Share on other sites More sharing options...
