  • Member For: 18y 10m 15d
clutch pack clearances are critical to correct shifting, even a different brand of clutch plate can alter this, different shims and thickness steels are available also but one does not just stick a new clutch pack in without doing all the tolerance checks
  • New Member
  • Member For: 13y 6m 18d
07 bf, 170k on clock with 380rwkw for last 6yrs 2 of those yrs with zf tune and still stock heat exchanger and box. Only problem I've had was leaking electrical connector on box.
Finally starting to slip so time for rebuild and will get a pwr heat exchanger when fresh box goes in.
  • Like 2
  • Member For: 17y 4m 18d
  • Member For: 21y 7m 7d
If you've ever pulled a watch apart (analogue) and thought fmd where did that spring go then that's how most people would feel about an automatic gearbox! A fcking nightmare...
Especially if you are doing it on carpet...Haha
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 3m 26d
89,000km. I've changed the heat exchanger at 30k and 70k.
I won't do it again, if it goes I'll deal with the consequences or trade in the car (just quietly)
  • Bronze Donating Members
  • Member For: 11y 9m 10d
  • Member For: 11y 9m 13d
Mk1 G6ET.
First and only mod I did was bypass the stock heat exchanger and fit a cooler at the front of the car -along with flush of gearbox oil.
