Gonads New Member 1 Member For: 10y 21d Posted 20/01/15 03:43 AM Share Posted 20/01/15 03:43 AM Correct me if I'm wrong, but a water cooled turbo should still have water flowing through the core after the car is shut off due to convection. The convection will stop when the core temp drops back to something similar to the block. You should not get any coking on the bearing surfaces with a water cooled turbo even if you thrash it right to the pit garage.Having said that I tend to take it easy for the last bit of the trip. 2 Link to comment Share on other sites More sharing options...
raised by monkeys Member 90 Member For: 10y 4m 30d Gender: Male Location: Whyalla, SA Posted 20/01/15 05:15 AM Share Posted 20/01/15 05:15 AM injectorsexhaust/dumptuneThis seen 325rwkw in mine (after major service inc. all new fluids and new centre bearing) Link to comment Share on other sites More sharing options...
foxtrot Member 77 Member For: 16y 4m 1d Posted 23/04/16 09:23 AM Share Posted 23/04/16 09:23 AM On 01/10/2014 at 8:47 AM, Peppy_t92 said: Great rant there Fiftyone, just to add... These cars can't be locked while the turbo timer is on, so yep sort of defeats the purpose as you may as well just sit in it for a minute or so with it running before you get out and have to stand there waiting for it to turn off so you can immobilise it... I initially installed one without this knowledge, and being known to give it a hard time all the way home, it's piece of mind to have it idling, the thermo fans are on, water pump is cycling the water through the engine/turbo, oil pump is cycling the oil through the engine/turbo and all the temps are equalising for a couple of minutes whether it helps or not, comparing to a F1 is irrelevant IMO... You do warm your car up before driving don't you? 07 is a great model mate, as stated above, pick a power figure, budget and go from there, welcome =) Hi. BA/BF and FG can all be locked when using a turbo timer no matter how it is wired in, you just use the key in that little slot in the door handle. Or if you wire it up the right way (or is that my way) you can use the remote during the time that the timer is operating. Cheers MD Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 9m 18d Gender: Male Location: Canberra ACT Posted 23/04/16 10:04 AM Share Posted 23/04/16 10:04 AM My EL maintains temp just fine when I'm taking a phone call. Wait, did I miss the main point? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,221 Member For: 16y 10m Gender: Male Location: Melbourne Posted 12/07/21 02:04 AM Share Posted 12/07/21 02:04 AM Link to comment Share on other sites More sharing options...
