raised by monkeys Member 90 Member For: 10y 7m 6d Gender: Male Location: Whyalla, SA Posted 20/10/14 02:02 AM Share Posted 20/10/14 02:02 AM Sweet build. Drilling out the hole for the swirl pot is a bit of a handy trick. Ive just had the same walbro pump installed but I have upgraded injectors.Is the fuel feed issue caused by not big enough injectors to get rid of the fuel coming through? Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1507006 Share on other sites More sharing options...
I JET Member 325 Member For: 12y 3m 9d Gender: Male Location: Wollongong Posted 20/10/14 02:15 AM Author Share Posted 20/10/14 02:15 AM ^ I'm running the standard intank and a process west surge & 044. The high pressure is due to a restriction in the return line. One fix is to drill out the restriction in the swirl pot like I did, the other less effective fix is to replace the return line between the rail and surge tank + a larger fitting in the surge tank. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1507007 Share on other sites More sharing options...
I JET Member 325 Member For: 12y 3m 9d Gender: Male Location: Wollongong Posted 23/10/14 09:37 PM Author Share Posted 23/10/14 09:37 PM Original coils started breaking up under load a few days after the tune. From what I've been told this is pretty common when they are subjected to more load / boost, Replaced with a set of genuine coils and re-gapped the plugs while I was at it. Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1507860 Share on other sites More sharing options...
I JET Member 325 Member For: 12y 3m 9d Gender: Male Location: Wollongong Posted 23/11/14 06:11 AM Author Share Posted 23/11/14 06:11 AM Soooooo.....clutch's? Yep I'm gonna have to start saving up for a replacement clutch kit. I've had the standard clutch slip on me twice since the power upgrade, conditions were the same both times, 4th gear pulls, up an incline from low rpm with clutch slipping when hitting full boost. It hasn't slipped on the flat yet, and still grabs hard in 1st 2nd & 3rd up hills. It must be a sign of things to come. I must say I'm not surprised with nearly 1000nm at the treads. I guess its better than having it sh*t itself all of a sudden, at least this way I can start putting some money aside now and be ready for a new kit when it becomes a problem.I'll have to go back and read through the huge clutch recommendation threads again..... Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1513741 Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 4m 14d Gender: Male Location: Rockhampton Qld Posted 23/11/14 06:44 AM Share Posted 23/11/14 06:44 AM Mines been having problems to. Started slipping on the dyno while doing the e85 tune a few weeks back. Reverted back to 98 while I save up for a new clutch and it does first n 2nd fine, slips top of 3rd and 4th is a no go with foot down with 350kw.Have read almost every clutch thread and haven't seen a bad thing about npc's single plate. have seen plenty of good and bad reports on Mals clutches. Will be ordering my npc single plate coppermix in a few weeks. Think it was about $1700 inc delivery with all the braided lines n sh*t and good for 430rwkw. Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1513747 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 17d Gender: Male Location: Adelaide Posted 23/11/14 06:48 AM Share Posted 23/11/14 06:48 AM RATE the NPC !! Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1513748 Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 4m 14d Gender: Male Location: Rockhampton Qld Posted 23/11/14 07:15 AM Share Posted 23/11/14 07:15 AM And half of the good posts about npc are from jet haha. They must be as good as people say or he has shares in npc.... Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1513749 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 6m 18d Posted 23/11/14 09:08 AM Share Posted 23/11/14 09:08 AM Direct clutch services twin plate less then 2k for a clutch to handle all the abuse that 1000rwhp can throw at it. I currently have a direct clutch twin plate ceramic with solid centres in my turbo e series with a t56 and 450hp gets heaps of abuse everytime it's driven. I've lost count of the amount of times I've sidestepped it from a standing start in 3rd and it's still in perfect condition when I pulled the box out to a check the flywheel bolts yesterday.Sent from my iPhone using Tapatalk Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1513770 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 8d Gender: Male Posted 23/11/14 10:50 AM Share Posted 23/11/14 10:50 AM What's it like harshness wise? Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1513792 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 6m 18d Posted 23/11/14 11:10 AM Share Posted 23/11/14 11:10 AM It's actually surprisingly good I thought it would shudder when I bought it but it's very smooth just requires abit more revs to get it off the lights but holds everything I've thrown at it so far between drifting and powerskids at powercruise to just driving around on the road Im definetly happy with it and the fact that if I completely f*ck it that it can be rebuilt for $600 to brand new spec. Sent from my iPhone using Tapatalk 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89288-i-jets-bf-f6-ute-build/page/6/#findComment-1513795 Share on other sites More sharing options...
