I Jet's Bf F6 Ute Build
I JET
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 9m 27d
Nice build mate but you are aware lead acid batterys release toxic waste into the air when recharged/charged
This needs to be dry cell bare min or swop locations !
  • Like 2
  • Member For: 12y 2m 22d
Ok I cant seem to be able to edit my previous post's that I reserved so I will continue on from here.
7. Exhaust.....I picked up a turbo back exhaust on flebay for peanuts. I was after a single 3.5 but couldn't pass up a bargain. Its an xforce 4" dump into 3.5", twin 2.5" cat back all stainless.
AVLDhal.jpg?1
  • Decided to wrap the dump. I weighed up the pros and cons. Being stainless I didn't hesitate.
BgrAcVx.jpg?1
owei1DL.jpg?1
RezZDZ4.jpg?1
  • The xforce system did not have a provision for the second o2 sensor after the cat. I'm not entirely sure if this will be utilized when it is tuned but I welded in a new bung so I'm covered either way.
YNJu7l7.jpg?1
8. Surge tank & Fuel Pump......Picked up an older style process west surge and 044 with a wiring harness. I replaced the elbow hose with a set of speed flow fittings. No check valve on the pump yet but I'm definitely going to add one.
m44VDDp.jpg?1
9. Swirl pot modification.......When I spoke to Joe about booking in the ute for a tune, we were discussing my mods and he mentioned I may be running too high a fuel pressure with the surge & 044 setup. I put a gauge on the car and sure enough he was right. So to fix this there is a small orifice in the swirl pot that the return fuel exits. This can be drilled out to help return flow and get the pressure back down.
  • I went in from the top as to pull the tank out the bottom is a royal PITA on these utes, specially without a hoist.
  • Hard lid off & tub liner out
  • Drill out spot welds on left side of front panel to access fuel sender
NjmlVMt.jpg?1
sX6FBLD.jpg?1
  • Fuel sender out
XgH6Fma.jpg?1
  • Underside
0CCp6EJ.jpg?1
  • Removed this black piece
6YS5oBb.jpg?1
  • The 2.6mm hole is the restriction
KA5krWk.jpg?1
  • Drilled out to 4mm
7ENewfm.jpg?1
  • All back together, checked pressure again at idle and its spot on now at 4 bar.
ZrCTF63.jpg?1
  • Like 4
10. Turbo side Airbox.... I bought a Nizpro 4" turbo side intake but it didn't come with an airbox so I decided to make my own. After researching other brands I noticed that none of the turbo side air box's really seal off to form an air box. They are more of a heat shield I guess. They do keep the pod filter out of site and tidy up the engine bay. (the Process West one probably works the best at being an airbox)
Note: this is probably one of those things that you're better off just buying. I happen to have a sheet metal press and a lot of spare time so I took it on.
  • The Nizpro intake & filter without an airbox
bDIoNuH.jpg?2
  • Watching motoGP, making cardboard templates
Gw84Dhq.jpg?1
  • Test fit
DSsOQGj.jpg?1
  • Side wall flat pattern cut out
0Ksp7TM.jpg?1
  • Lid flat pattern cut out
qXuY7ka.jpg?1
  • Side all folded up
JfE715q.jpg?1
  • Lid folded up
krEUXN1.jpg?1
  • Holes all drilled. Was planning to get it powder coated but im keen to get it all finished and installed before the long weekend. So I settled for metal primer and satin black pressure pack.
Ssi1P2K.jpg?1
  • Picked up a nutsert kit & some rubber & foam seal to finish off the airbox nicely
xpAjQFn.jpg?1
That's all I had time for this afternoon. I'll get the airbox finished and installed first thing tomorrow.
  • Like 2
^ I use to work as a mechanic. I got out of the trade about 6 years ago because the money is shocking. When I finished my apprenticeship I stayed on at tafe for a further 3 years and did a Diplomer in Mechanical Engineering while working as a mechanic. When I was in my 3rd year of that course I left the mechanical trade and began working as a Fitter doing mainly shut down work. Through that work I gained contacts and was offered a job at a local engineering firm as a Mechanical Designer.
  • Like 3
