  • Member For: 10y 5m
  On 11/05/2015 at 2:36 AM, I JET said:
^I know...lol...... Still a kid at heart. The toys just became a lot more expensive.
Mum thought it made her looked like a hoon! All my mates thought it looked sick :) and they did there mums car with liquid paper!! Lol.
The first set of tires I put on my Corty back then was the good ol Bridgestone Eagers just so I had the raised white letters, cost me $1100 back then and when your 16 and work part time that was a lot of saving...
  • 4 weeks later...
  • 1 month later...
  • Member For: 12y 5m 6d
Been a while since I've posted in here. The F6 has had a few things done lately.
  • Clutch
The standard clutch started slipping quite badly under power in 3rd & 4th a few months ago. It was inevitable after subjecting it to the added power and torque. I decided to go with a NPC Single Plate Cushion Button clutch. Rated quite high - over 460 rwkw. I wouldn't recommend this clutch for a daily driver, basically it sucks for hill starts and slow speed maneuvering. I knew what I was buying and im very happy with the clutch. My car only gets driven on the weekends for fun so it suits my driving perfectly. It will stand up to a lot of abuse and still hold power after my next round of mods.
The NPC kit comes with your pressure plate, clutch plate, flywheel, slave cylinder + on top of that I ordered new flywheel bolts, pressure plate bolts, spigot bearing, rear main seal & I replaced my tail shaft center bearing while the box was out.
kp7oZ9Y.jpg?2
The standard ap racing twin plate was a beast. Very heavy.
G9sxmk7.jpg?1
The new NPC kit. - much lighter rotating assembly - With the new clutch I noticed the car spins up a lot quicker in 2nd, it breaks traction instantly with boost instead of gradually.
Il683tN.jpg?1
  • Power steer pump & high pressure line
My p/s pump started leaking quite badly and was also leaking from the o ring on the high pressure line. I replaced both to be safe.
UZPVks2.jpg?1
5i7SvuE.jpg?1
  • Rear rotors
Still running the stock pbr rotors on the rear after 85,000 kms and I can honestly say 'they are completely finger f*cked'. They are badly warped & I didn't realize just how bad they were until I replaced my front rotors a little while ago. I should have replaced these at the same time.
I went with a set of RDA dimpled & slotted rotors for the rear. DBA T3's were my first choice but at over twice the price I couldn't justify it considering the braking force on the rear of a ute is so small compared to the front.
zLzv56I.jpg?1
O3ljOC1.jpg?1
  • Wheels
I thought I'd treat myself to an early birthday present.....I picked myself up a mint set of genuine fpv gt 335 19's. I've always liked these rims and was lucky enough to pick up this set, as new with good oem dunlop tyres for a great price.
5bXxsp0.jpg?1
gXPRvwQ.jpg?1
J1RsxjS.jpg?1
I'm really happy with the overall look of my car now. To me, these rims were the finishing touch.
  • Like 4
  On 04/07/2015 at 3:35 PM, stubbietubbie said:
that arse still hangs too low, personally.
I'll start by saying 'that's what she said'
its sitting a touch lower than normal in that last pic, I had my 4 standard rims & tyres in the boot + the rotors and ps pump.
I personally don't like it when the arse hangs low
EDIT - the pic in my signature is how it normally sits...
Edited by I JET
