  • Formerly EGOBFXR6
  • Member For: 17y 4m 26d
I just sold an F6 recently so I can seriously appreciate how good Brembo's are - But for the price and ow hard I drive, it's overkill...
Just a good set-up over stock would be fine. Just want to see what I can do with the current set-up first...
Cheers,
Dan
  • MattyP
  • Cruise Control
  • Member For: 13y 1m 27d
Did you have 6/4s or 4/1?
I've been looking around for a little while and found the full package for sub 2k
  • WOT?
  • Moderating Team
  • Member For: 12y 4m 6d
Back on topic ;)
I think there are a few things that can cause shudder.
Is it only while under brakes?
Perhaps take it to the shop that did the work and get them to check what it is - also find out what they put on the car (a pic of the rotor would probably get you an answer on here)
  • 570Nm @1800rpm
  • Member For: 21y 9m 10d
Hahaha I've read it all now...
Phew... Thanks lads :spoton:
There were plans to go T3's/T2's, new fluid, braided lines and some nice pads but now I'm not so sure.
The seller was good enough to give me his vehicle receipts and the front brakes were done about 10,xxxkms ago. It doesn't specify the exact combo but Matt seemed to think they were slotted/drilled RDA's but not really sure on the pad.
Can a rotor crap out after 10,xxx km's? He assures me that it wasn't driven hard and I've pretty much babied it since I've had it. Pedal feel is really nice but the shudder is horrid at anything above 70km's p/h and it feels like the last bit of 'braking' doesn't really pull the car up that sharply...
Trying to avoid having to replace the brakes since the upgrade was so new and I've got to do the trans service, trans cooler install and the diff bushes...
Anyone have any idea what's going on? Is it the suspension? Can I do anything about it or would there be some kind of warranty on a pretty much new rotor?
Thanks for all the input guys,
Dan
If good quality rotors were put on you would not need to machine them after 10000kms. Post a photo of one of the front and I'll tell you if they are RDA or not.
If it was me I would not waste money on machining RDA rotors. Save yourself the grief and just bin them :spoton:
  • Member For: 17y 7m 7d
When my BF had the shudders it was cured 80% or so by replacing the worn out front suspension bushes with Superpro. Then the remaining 20% was new rotors (DBA4000 at the time).
I'd guess the movement of the suspension under braking caused the warping of the rotors, but not 100% sure. Could account for rotors warping soon after fitting them or having them machined!
Great stuff Dan, I retired from CC duties but might have to (again) throw another one together. There's also another monster blue ute that is nearly done being built and I'm sure the owner will be keen for a drive, plus the chat recently in WA section asking when the next cruise is :)
Keen to see it in person!
Edited by -Stever-
  • Like 4
  • All stock bar the k&n panel filter
  • Member For: 13y 3m 18d
Dan (OP, not me) for new WA CC!
  • Like 2
