.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 3m 10d Gender: Male Location: Perth Posted 21/09/14 03:49 AM Share Posted 21/09/14 03:49 AM I appreciate that these boxes can be a bit notchy, especially the 1st to 2nd gear change, but has anyone with these boxes experienced 2nd gear grinding? It happened maybe once or twice in my FG XR6T and was me being lazy with the clutch, but it's happened in my GT much more frequently when I'm giving it a good boot full and shifting hard 1st to 2nd. It's not as a result of me being lazy with the clutch either, as I've made a conscious effort to make sure the clutch is pressed in fully...if it was in any further it'd be through the firewall.It's been more pronounced since having a Rip Shifter fitted, but I'm told by the shop who installed the Rip shifter that it was setup correctly with the positive stops as if they weren't it would pop out of gear etc. I also had a mate drive my car to see if it was just me and same thing happened to him twice in a short drive, the car was nice and warm too so it's not just a symptom of being cold. Is this just normal for these gearboxes, or does it sound like there's something wrong? My turbo I could be mid drift at the top of first gear and slam 2nd hard without any issues or grinding, but I'm somewhat nervous about doing the same with the GT...which is disconcerting.I've also noticed that with this car once I've let the clutch out after a gear change there's a tiny bit of play in the clutch, in that I can flick it out a tiny bit further than it releases on its own by lifting my toes up underneath the pedal. It also feels a little loose at which point and creaks a little, which I'd expect with an older model, but not a brand new car with 5,000kms on it. This is my first twin plate clutch, so is this normal? Or should it pop all the way out by itself and have no more movement at which point? Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/ Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 10m 22d Gender: Male Location: South West QLD Posted 21/09/14 11:01 AM Share Posted 21/09/14 11:01 AM Where's pazzo when you need him?Didn't he have some similar problems with his manual? Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500771 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 4m 14d Gender: Male Posted 21/09/14 11:58 AM Share Posted 21/09/14 11:58 AM My box is the same. Have been told its completely normal by ford engineer. Tolerances vary from box to box, but I'd definitely be looking at changing the oil to something different or checking its capacity. It really disheartens me also, as its not spot on where I'd like it to be. I'll be experimenting with the above once I get the diff sorted and some E85 in the tank! Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500801 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 8m 1d Gender: Male Posted 21/09/14 08:36 PM Share Posted 21/09/14 08:36 PM (edited) I'm here!!!!! Yeah mine and alot of people are in same boat... Have changed oil 3 times now and still same thing... Guy who works next door to me bought a fg Mk 2 T brandnew with 8ks on clock... Same FARKING thing..Fird will say it's normal no matter what you say... Mine has been back 4 times now..when it's like 2deg in morning it's at its worst.. Once warm can still feel it grinding ever so lightly.. I take off and change into second ASAP or drop it from 1st to neutral then to second.., I don't boot my car anymore because of the problem..This will be my last Ford ever after this due to Ford just brushing it off, they will just keep changing the oil and say.... Within tolerance! Edited 21/09/14 08:36 PM by Pazzo Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500821 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 3m 10d Gender: Male Location: Perth Posted 21/09/14 09:53 PM Author Share Posted 21/09/14 09:53 PM Hmmm, thanks Pazzo...that's pretty poor on Ford's part really! Mine only ever does it if you're really botting, I.e. full throttle changing 1st to 2nd. I might give Mal Wood a buzz today and get his thoughts on it. Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500828 Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 11y 1m 21d Gender: Male Location: Shellharbour NSW Posted 22/09/14 02:58 AM Share Posted 22/09/14 02:58 AM (edited) I think it comes down to the fact that Ford have quiet a big ratio gap between 1st and 2nd compared to other tremec users.If you try and shift to fast then it doesn't give 2nd gear time to match the speed of 1st.Having triple syncros might make shifting easier but it also means more time for them to all line up so the shifting ring will slide over the syncros and onto the gear.Know this might sound obscene in this day and age but have you guys tried double clutching and heel toe to match revs.It's hard and takes practice but its worth giving it a go. Edited 22/09/14 03:02 AM by "Captain Retard" Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500876 Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 10m 22d Gender: Male Location: South West QLD Posted 22/09/14 03:16 AM Share Posted 22/09/14 03:16 AM 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500881 Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 1m 29d Gender: Male Location: ACT Posted 22/09/14 04:08 AM Share Posted 22/09/14 04:08 AM Posted 20 May 2014 - 08:52 AMI have been using this stuff in all my cars for many years...My BA MK2 Turbo 6 Speed " loves " the stuff... I also use it in my Diffs.Manual Gearbox and Diff Treatment Nulon G70Nulon Manual Gearbox and Diff Treatment with PTFE offers maximum lubrication and anti-wear protection to the gear and bearing surfaces of all types of gears (helical, spur and worm drive). Nulon G70 combines a balanced blend of Polytetrafluoroethylene (PTFE) with other extreme pressure and anti-corrosion compounds. Nulon G70 is suitable for use with all synchromesh rings and limited slip differentials.The PTFE particles in Nulon G70 range from .4 to 40 microns. The smaller particles, when subjected to pressure and temperature, impregnate the friction surfaces thus reducing friction and offering residual lubrication and corrosion resistance even during lay-up periods. The larger PTFE particles circulate with the normal gear lubricant and create a cushion between gear surfaces, dramatically reducing gear pitting. This cushioning effect is important in that it reduces noise caused by minor irregularities of mating surfaces which are responsible for the very common "period noise" experienced in differentials.Many modern gearboxes suffer from poor gear shifting when the gearbox is cold. As a result a number of manufacturers are recommending a lighter grade of oil, and in some cases automatic transmission fluid. These lighter grade oils provide superior gear changing at the expense of reduced life of gears and bearings, because the lower viscosity oil does not have the degree of EP (extreme pressure) protection. Nulon G70, due to its EP characteristics, will greatly improve protection as well as dramatically improve gear changes.Note: G70 is suitable for all gearboxes including passenger cars, trucks and industrial gearboxes.G70 is also compatible with, and suitable for use with, automatic transmission fluid and engine oils, where they are the manufacturer's recommended lubricant for manual gearboxes.http://www.nulon.com...t/#.U3qKJdL6uz4 Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500893 Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 3m 28d Gender: Male Location: Perth Posted 22/09/14 04:42 AM Share Posted 22/09/14 04:42 AM Double clutching on up shift? Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500898 Share on other sites More sharing options...
"Captain Retard" Member 1,417 Member For: 11y 1m 21d Gender: Male Location: Shellharbour NSW Posted 22/09/14 05:23 AM Share Posted 22/09/14 05:23 AM Yep Link to comment https://www.fordxr6turbo.com/forum/topic/89227-tr6060-2nd-gear-grind/#findComment-1500905 Share on other sites More sharing options...
