  • Carnage on the Garage Floor
  • Member For: 15y 19d
I'm happy with my MTA750 now sorted but time over, I'd do the GTX76r. Such good value when on special. Basically an easy 500hp with mad spool.
  • Moar Powar Babeh
  • Member For: 19y 8m 7d
The GTX3576 runs a 4" inlet so you would at least be up for a new silicone joiner.
My list of bits I will be purchasing:
post-7403-0-34132200-1411093546_thumb.jp
  • Like 3
  • Member For: 16y 4m 11d
Lennox,
You might need to factor in the costs for the following:
* Injector upgrade - I am running Bosch 1000ID's
* Flapper mods - easier to do when the turbo is in bits to fit the GTX3576. Probably essential.
* Clutch upgrade.
* Intercooler might - not sure if it's essential or just very helpful. I grew tired of hot weather power drop-off.
* Exhaust and cat upgrade.
* Fuel pump upgrade - you might find this is essential.
Guys - you can see my use of the words "probably" and "maybe". Let's know what's essential when fitting a GTX3576 turbo centre.
Lennox - Í could have saved a couple of thousand by getting the turbo upgrade and intercooler done the first time. The lack of puff over 5500rpm and the hot weather drop-off have always bothered me but I thought a cat upgrade and bigger injectors would keep me happy. Biting the bullet and getting it all done once means you will save the cost of the 2 or 3 tunes before you decide to go for the turbo and intercooler upgrade.
Yes this turbo from MTQ comes with a new inlet housing that requires an adaptor to fit it onto the Process West intercooler. I'd contemplated having a go at fitting it myself. Glad I didn't when I saw the work that Autotech guys did.
PAH
Edited by PAH
  • Member For: 19y 3d
  On 19/09/2014 at 1:37 AM, Lennox said:
What else do you need once you buy the turbo for 1450 or whatever? Does that just go in your factory housing and you're ready to go?
a new inlet hose
a new outlet hose
front cover drilled and tapped for a boost reference line
a rear housing with port job
an actuator
an actuator bracket
  • Like 2
