  • Too heavy needs boost
  • Member For: 11y 9m 6d
wheel nuts are all tight. ill put the front up tomorrow and check to see how clean it is. also check the seating of the wheel and not sure if I have hub rings with stock 19". ill check the rears aswell. what's the right torque the nuts should be cranked up to aswell. not sure. cheers.
  • Member For: 13y 4m 9d
I had the same thing 4 tyres fitted, drove fine on the way home up to around 80 kmph. First time I got on highway had a bad vibration, thought they stuffed the balance up. Ended up getting them balanced another two times, still bad vibration.
Anyway told shop wasn't happy and got sent to a truck alignment shop where they jacked up the car and spun the wheels up while on the car still and it turned out two of the tyres were faulty.
  • Bronze Donating Members
  • Member For: 12y 1m 5d
120Nm (I think)
no ring on the standard wheels
  On 11/09/2014 at 11:21 PM, turbotrana said:
Get rebalanced. Happened to me a couple of times where prior to new tyres OK then new tyres and vibrates. The kids doing the balancing stuff up sometimes.
^^^ or at least check that a weight hasn't come off
  • Member For: 12y 3m 17d
Just on the topic of wheel weights, I had nitto invos fitted a few months ago and was surprised that two of the wheels required no wheel weights at all. lol doesn't really help you , I've just never seen it happen before.
had nittos before these. They were fine and also had them fitted by the same people. never had a issue with them. new tyres a cheapies. Achilles atr 2.
all wheel nuts are tight. hubs are clean and inside of the wheels are clean. from what I could tell from being a dumb fark with cars it seems all good. going to get the balance checked again and if its still there melt the rubber and buy 20"
Edited by Bizkets is fat?
  • Like 2
