07 Bf Mkii Xr6T Mods?
Mersin
  • Member For: 10y 4m 16d
I was quoted $350 for the relocation of the battery, the new piping along with the pod filter located where the battery used to be. I know turbo back exhausts are expensive but I'm not in a huge rush, I'm looking at bargains for second hand parts, same with the intercooler.
Unless doing the mods for $350 is a bad thing that will cripple my car then ill consider something else, from what I've seen and read in my eyes its looks cheap and worth doing. Am I missing something? Will those changes damage my car, or be too much for the engine (internals) to handle?
Obviously I need a tune up and better injectors but that would be the last step, correct me if I'm wrong.
  • Member For: 12y 1m 18d
$350 is pretty good but keep in mind that different intercoolers require different piping arrangements. So it's probably best if you purchase your intercooler first.
Have you decided on what power level your after and or what your budget is? Knowing those two things will make it easier to give advice. I was just assuming that your on a minimal budget.
  • MattyP
  • Cruise Control
  • Member For: 12y 8m 23d
That's cheap as for a turbo side
Plus they sound awesome.
Turbo sides don't really need an adjustment to the tune but to get the full advantage of them you should get one
I only got the auto cos the ZF thought it was one of best gearboxes out there? I'm not looking to go over 400 rwkw though basically just the changes I mentioned. Is the gear box able to cope with those changes?
So far my budget is about 2-2.5k
$350 for piping, relocation of battery and pod filter(air filter whatever it is)
so ill have around 2k leftover to do exhaust, intercooler, injectors and tune, is that possible or do I need more (mind you I'm looking at second hand parts, unless I should steer away from second hand)
  • loitering with intent
  • Member For: 21y 5m 8d
350rwkw is streetable.. IMO anything too much over this is just tyre frying and requires
more money and more mods more skill to get the power down and avoiding obstacles
Depends on your goal .Make no mistake this still a lot of power.
again just my opinion
for what you are after
panel filter
cat
injectors
Intercooler ( PW or plazmaman avoid Monza and Wog coolers)
Tune ( this will cost you ~ $1500 alone with xcal box)
This should see you over 300 rwkw without relocating battery etc if that's your goal at a price
Will need a bit more boost to reach a figure as not the most efficient.
Maybe save a bit more to cover some extras as you will chew up $2.5 k pretty easy
ZF should be OK at this power level but I would recommend a full service as a minimum ( pan / filter/ oils etc)
Again this will cost you additional hundreds of dollars.Not a cheap service and will vary by shop
Second hand bits have saved a lot of members lots of money but your recourse is limited if
it doesn't do what it says on the tin
hope this helps , as always speak to your tuner for a steer
  • Like 2
I appreciate your comments and will take everything you said into consideration.
I was actually going to service the transmission but after I heard the quote for changing oil, pan, filter etc I backed off and said not to worry about (was around 8-900).
Would ebay be the best place to buy second hand parts I.e. intercooler and exhaust or are there are websites or places that offer better and cheaper options.
Also what stage intercooler would be sufficient?
  • Member For: 11y 1m 5d
Buf-Phoon's advice is very very good, I made 328rwkw with all the mods listed (edit: you also need a fuel pump), although I used very high quality brand new parts. I still have the standard crossover pipe intake but with an F6 lower snorkel, sound awesome enough for me so no turbo side yet. My BF still has only 60k km on the clock so yours might need a bit more work though.
Edited by RB Snake
  • Member For: 17y 2m 2d
Watch out for ZF flaring between gears, or when it gets really worn, refusing to change to higher gears under WOT. Mine wouldn't shift 3-4 for a long time... rebuild $3000 and good again but don't let it go too long as it takes a looooong time to relearn how to shift smoothly, or at least mine did. Was smashing into gears for a couple months and I drive it 500km a week...now it's good as gold again 99% of the time. Just if I change at the wrong time I can still get the bang I posted about.
I bought my Nizpro cooler and pipes for about a grand second hand. New 42lb injectors, new full Manta 2x2.5" exhaust, new intank Walbro pump. Custom tune and XCAL3 device..about 5300 I think. Good for 120mph and 11 second quarters. I couldn't get a good launch technique so had a lazy 60' time and still got 11.9.
You could get away without the full exhaust though and save a grand easy. Maybe another $3-500 on cooler.
