Serangan Member 103 Member For: 11y 9m 16d Gender: Male Location: Hobart, Tasmania Posted 11/09/14 12:35 AM Share Posted 11/09/14 12:35 AM (edited) Hey guys,Firstly car is tuned using hp tuners.Just got my car retuned and now having an issue of the fuel trims not doing anything. I was with the tuner this morning and we went through it all and we can't see any reason why they're not working.The o2 sensor is giving readings, and I've also replaced this.Im guessing part of the issue is the fact that the car isnt entering a closed loop, but why its doing that I have no idea.Im getting a copy of the tune file next time I'm out there so that I can have a look at it and compare it to a stock file to see where the changes are.Has anyone come across this kinda of issue before?Thanks Edited 11/09/14 12:40 AM by Serangan Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 16d Gender: Male Location: Perth Posted 11/09/14 01:16 AM Share Posted 11/09/14 01:16 AM How do you know the trims aren't working. Is your tuner logging the correct parameters? Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498560 Share on other sites More sharing options...
Serangan Member 103 Member For: 11y 9m 16d Gender: Male Location: Hobart, Tasmania Posted 11/09/14 01:41 AM Author Share Posted 11/09/14 01:41 AM (edited) Well I just captured this using forscan.Initially its open loop shown by the top graph, then jumps to closed loop (the little jump in the red line) and the fuel trims start working (long term ones are green and blue, short term pink and yellow) then the red line jumps to a fault and the fuel trims go back to zero again, after reaching about -17%Orange is the 02 sensor, which is clearly reading stuff.The car wasn't started till about 110 seconds, and the drop in the o2 sensor is caused by me disconnecting it to see if its reading something. Edited 11/09/14 01:41 AM by Serangan Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498569 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 16d Gender: Male Location: Perth Posted 11/09/14 01:44 AM Share Posted 11/09/14 01:44 AM Log ltft2 and see what happens. Tuner could have disabled ltft but unlikely Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498571 Share on other sites More sharing options...
Serangan Member 103 Member For: 11y 9m 16d Gender: Male Location: Hobart, Tasmania Posted 11/09/14 01:46 AM Author Share Posted 11/09/14 01:46 AM Sorry, the pink one is ltft2, which seems to mimic ltft1? Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498572 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 16d Gender: Male Location: Perth Posted 11/09/14 01:50 AM Share Posted 11/09/14 01:50 AM Post you tune if your tuner will share it. Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498573 Share on other sites More sharing options...
Serangan Member 103 Member For: 11y 9m 16d Gender: Male Location: Hobart, Tasmania Posted 11/09/14 01:52 AM Author Share Posted 11/09/14 01:52 AM Will do when I go get it tonight. ill ask if he's happy for me to upload it Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498575 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 16d Gender: Male Location: Perth Posted 11/09/14 02:13 AM Share Posted 11/09/14 02:13 AM Even screen dumps of the fuel tabs will be a good start. Have you deleted the rear o2 sensor? Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498582 Share on other sites More sharing options...
Serangan Member 103 Member For: 11y 9m 16d Gender: Male Location: Hobart, Tasmania Posted 11/09/14 03:23 AM Author Share Posted 11/09/14 03:23 AM Being a ba it never had an 02 sensor, so I assume that hasn't been changed.Heres the tune file, he said he's happy for anyone to look at it, not allowed to upload .htp files, so its linked belowhttps://www.dropbox.com/s/1hrnrfw3ssf06tk/C56TP%20Tuning%2016psi%28green%20giants%29.hpt?dl=0Thanks Ralph Wiggum, if you need anything else let me know.Basic stuff about the car;2004 mk2 ba bosch 968 injectors (42lb) 4" dump4" 100 cell catstock from cat back12 pound actuator valves springs donebigger front mount with turbo side intake. Don't think this would effect the o2 sensor at all but you never know... Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498594 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 16d Gender: Male Location: Perth Posted 11/09/14 03:39 AM Share Posted 11/09/14 03:39 AM 02 senor temp ltft enable is set to a touch over 1000degc.Stock value is aprox 280deg.it won't be using ltft as the sensor temp for enable is way too high. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89157-long-term-fuel-trims/#findComment-1498600 Share on other sites More sharing options...
