  • Member For: 12y 9m 15d
The less amount of coolant in the system, the cooler it will run, but the lower the boiling point also.
Water with Redlines 'water wetter' is the go.
  • Member For: 17y 6m 21d
Nobody would run 100% I was just adding it in...
Sometimes straight water is no good for a modern engines cooling system
Water/glycol mixture is more viscous (thicker) and your waterpump is designed to pump this thicker mixture around...
Water would pump around faster and actually spend less time in the engine/radiator and lose it's efficiency as well
I know this would be a very small difference,
but as butt plug always says, the ford engineers spent millions working this stuff out, hence ford recommending 33% coolant/water ratio
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 11d
And exactly what we/I use and installed ;)
Leave the technical stuff to those paid to find out
But for a pure race/temp situation water with a "wetter" is brilliant
But I think 1% of us would ever find the benefit
Edited by Butt Plug
Spot on
And I'll add one more thing, another great mod for controlling temps on the track would be a good sized engine oil cooler
  • Member For: 14y 4m 23d
just to update where I'm at with it.
The car is manual
I had some time to do some work on the car.
Yes the oil is fried, 10w 60 penrite 1 week old.
Also every exhaust and turbo bolt is loose after the track day, and blown out most gaskets (most of my issue on the day, I think)
I had the turbo off and had a real good look at how the heat sheilds work (sh*te) If the turbo (big lump of cast iron is basicly running red hot, radiant heat is blasting at the middle of the head and compressor side of turbo) both made of great heat sink materials, transfering all that heat into the air passing through.
So I got some ss lock nuts a new gasket set, and thermal wrap for the turbo, headers and dump., and a new genuine ford o2 sensor.
I have digital readout in the car for the IC in and out, part of the IC temp controller 45psi pump and atomisers. on the track it reached 45deg at WOT until end of straights, then dropped to high 20's by end of first corners (works really well)
After I fit the thermal wrap it will be interesting to see how much the engine temps and IC temps change ?? If I'm right about the open fire place (turbo) cooking the head and compressor, this should make a big difference.
I'll get a new tune next week or 2 on e85, see how it goes.
I watched a tuner and noticed he let the cars cool before re-runs. I'll make sure the tuner gets it nice and hot to be sure it's actually tuned to do more than race off at the traffic lights.
  On 16/09/2014 at 7:37 PM, Wilko16 said:
Good stuff! If your doing all that an oil cooler is cheap insurance
agreed.
I also noticed FG's have bigger oil and coolant lines going to the turbo. Might be worth getting FG piping from a wrecker.
A bugatti veyron has 10 radiators, not sure where I could fit another 9 on a ford :)
Behind the fog light I think is the only place you could fit an oil cooler...
FG F6's have an oil cooler just above the filter as well... Water/oil style same as the auto trans
