Engine Rebuild Options
QIK06T
  • Member For: 10y 5m 11d
Gday So I'm wanting to discover my options regarding my BA motor and how to get it up to spec to typhoons motors. Will I need something like this ...
http://pages.ebay.co...EBAY-AU&alt=web
out of a bfmk2 turbo or perhaps a whole engine or just build rods and pistons. I'm particularly looking for the most cost effective approach. Thanks
  • Member For: 13y 14d
There are plenty of low 300Kw Ba's around. If you can handle a few less Kw stick with your BA engine, if it goes bang replace it with a BF engine.
My understanding of the differences between the two is rods, pistons, timing cover and ecu. Please correct me if I'm wrong.
Guys, do BA's have one or two knock sensors?
  • Member For: 11y 2m 12d
From memory If putting a fg f6 short in a b series. B series sump needs to be used, oil pickup needs to be moved which requires re torquing a main cap. Dip stick needs to be tapped in a diff spot on the block and an engine mount needs to be moved.
There is a great thread on AFF about installing an fg block in a b series.
Edited by barnz
