arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 16d Gender: Male Location: Perth Posted 23/09/14 01:50 AM Share Posted 23/09/14 01:50 AM Yeh, hope you dont have to increase radiator size as there is minimal room left. Size isnt everything. Design is very important. Its not all about cramming in the largest that will fit.I am sure it will work well. Do you have back to back dyno figures and inlet and outlet temp results to compare against the other coolers you have ran. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501054 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 12d Gender: Male Location: Adelaide Posted 23/09/14 02:03 AM Share Posted 23/09/14 02:03 AM Dude post 1 lol 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501056 Share on other sites More sharing options...
ripped6 Donating Members 246 Member For: 13y 10m 11d Gender: Male Posted 23/09/14 02:18 AM Author Share Posted 23/09/14 02:18 AM On 22/09/2014 at 10:58 PM, Kosij said: Based on that size I would say it would be fair to compare it with a process west 3 cooler, 500x425x100 is the process west size. I've done a few high 400rwkw pulls on the dyno and IT climbed 5 degrees.indeed it would be a good comparison to the process west stage 3 as this cooler is 480 x 430 x 100. the nizpro cooler was/is 480 x 440 x 80 and suffered 5 degrees of soak after the first run. had my tuner done more runs I believe this would have been an exponential figure. On 23/09/2014 at 1:50 AM, arronm said: Yeh, hope you dont have to increase radiator size as there is minimal room left. Size isnt everything. Design is very important. Its not all about cramming in the largest that will fit.I am sure it will work well. Do you have back to back dyno figures and inlet and outlet temp results to compare against the other coolers you have ran.based on the stock temp gauge the car is running the coolest it ever has so I doubt I'll need a new radiator. and as far as quality goes that's one of the reasons I no longer run the Chinese bar and plate coolers that saturate the market. The only data I have for the last cooler is already posted, I will chat to my tuner when I hopefully collect my car today. hope to do at least 3 back to back runs if not more at the same boost pressure as the previous cooler and see how it fares. Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501057 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 16d Gender: Male Location: Perth Posted 23/09/14 02:35 AM Share Posted 23/09/14 02:35 AM Yeh back to back with same boost will be good. Would be interesting to just run it straight up with out changing anything to see what if any difference there is.My car didnt overheat either until I took it to the track. If yours is just a street car then stock rad should be fine. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501059 Share on other sites More sharing options...
ripped6 Donating Members 246 Member For: 13y 10m 11d Gender: Male Posted 23/09/14 02:50 AM Author Share Posted 23/09/14 02:50 AM Unfortunately im upgrading the fuel system and sorting out my overboost issues (new exhaust housing, port job and actuator) so direct back to back runs are out the window. so will have to settle for same boost and possibly timing depending on power level. luckily the temperature today is almost identical to when I ran it up 3 weeks back.what cooler do you run arronm? do you run an ethanol fuel? tube and fin coolers allow a lot more air to pass through to the radiator then a bar and plate cooler will. ethanol fuels burn cooler as well. Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501060 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 16d Gender: Male Location: Perth Posted 23/09/14 05:41 AM Share Posted 23/09/14 05:41 AM Read my Sig apparently I am sponsored by NIZPRO. I do use mostly nizpro gear, so their cooler. I run P100. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501088 Share on other sites More sharing options...
ripped6 Donating Members 246 Member For: 13y 10m 11d Gender: Male Posted 23/09/14 06:42 AM Author Share Posted 23/09/14 06:42 AM ah nice, cant complain about free parts. Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501094 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 2m 5d Gender: Male Location: A big bridge over a river in South Australia Posted 23/09/14 11:19 AM Share Posted 23/09/14 11:19 AM You must of got it back from the tuners Jarrad coz it's pissing down atm and isn't that what always happens? Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501144 Share on other sites More sharing options...
ripped6 Donating Members 246 Member For: 13y 10m 11d Gender: Male Posted 23/09/14 11:36 AM Author Share Posted 23/09/14 11:36 AM No luck Ben, the extra pump I had fitted on my surge tank has sent my regulator off the deep end :/ ordered a new reg and fitting kit today from plaz 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501147 Share on other sites More sharing options...
mummba Member 525 Member For: 15y 3m 6d Gender: Male Location: perth Posted 23/09/14 12:50 PM Share Posted 23/09/14 12:50 PM free from nizpro????? that's funnier than cheap from nizpro haha 5 Link to comment https://www.fordxr6turbo.com/forum/topic/89070-nizpro-fg-intercooler/page/4/#findComment-1501154 Share on other sites More sharing options...
