  • Member For: 10y 7m 28d
Gday Lads, first post on here
So I recently purchased a Dec07 XR6T and when doing my first service and was changing the oil I noticed the car had a Z9 filter. I noticed as the filter I had purchased was the shorter/fatter Z516 and it was obviously not for the car as BF and up changed to this.
Does this mean my engine is in fact a BA motor?
So this opens up a few problems for me, as I was under the impression I had the stronger F6 internals.
Is there Some way I can verify the internals of my engine. Is it possible to change the sump whilst retaining the stronger F6 bits.
Also it's worrying to know why this change was made in the first place. I'm actually really disappointed about this.
I was hoping I could get some help on this as I'm confused as F@ck.
Thanks
Ed
https://www.fordxr6turbo.com/forum/topic/89026-bf-xr6t-engine-oil-filter/
  • Member For: 19y 4m
Is the engine number and the vin number the same and does it have a service history with it ?
  • Member For: 11y 4m 29d
I dont think there is any need to check. Z9 and Z516 are different size thread's. No reason a Dec 07 BF should have that filter other than its a BA block... In my non professional opinion. BUT there is the two knock sensors thing on bf onwards so im not sure how you would go about fitting a ba bottom end in there.
that's the trans heat exchanger.
My point was the only explanation, that I can think of anyway... It must be a ba bottom end
Edited by barnz
