genuine honest person Member 2,769 Member For: 11y 4m 24d Gender: Male Location: near brisbane Posted 28/08/14 07:07 AM Author Share Posted 28/08/14 07:07 AM ok ,can you explain a bit to me as I have no idea . so these figures are nothing ? so it will still be slow ? obviously I got my hopes up to soon . Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495805 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 21d Gender: Male Location: Adelaide Posted 28/08/14 07:41 AM Share Posted 28/08/14 07:41 AM Its roller torque that is a multiplication from your auto transmission To keep this some what simple a new xr6t lays out around 270fwkw and 500 ish nm at the engine Ba around 240fwkw and 450ish Your bus tuned would now be making "roughly" 320fwkw and 600nm in true flywheel figure anything to the wheels is a loss from there on in Peak Torque figures are one thing like say your old figure of 830nm "multiplied at the wheels" But if it shoots up and down fast you will get hammered at the strip by the guy with 600nm "multiplied at the wheels" whose torque spread is longer across the rpm range Its all about a better "average" spread of power/torque for longer Peak values are good for the dyno sheet Better averages are better for racing Mainline have one of the best "figures" and its called TORQUEd and will always be the lowest but most correct on a dyno sheet 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495811 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 10m 5d Gender: Male Posted 28/08/14 08:50 AM Share Posted 28/08/14 08:50 AM ^^^This guy doesnt even own a dyno................................... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495825 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 4m 24d Gender: Male Location: near brisbane Posted 28/08/14 09:47 AM Author Share Posted 28/08/14 09:47 AM when I pick up the car tomorrow ,I will take my camera and take some photos of the dyno screens .so that you can have a look at it for me .thanks for the reply . Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495842 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 4m 24d Gender: Male Location: near brisbane Posted 28/08/14 10:27 AM Author Share Posted 28/08/14 10:27 AM just found that Intune motorsport have some ITMS valve springs on special for $250 , are they any good ? .Also watched the video from Atomic how to remove valve springs whichlooks ok for me to do . The guy that is tuning the engine for me has one of these tools (he may lend it to me ?) thanks for any help or info Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495857 Share on other sites More sharing options...
matt036 Donating Members 280 Member For: 15y 5m 14d Gender: Male Posted 28/08/14 10:51 AM Share Posted 28/08/14 10:51 AM I wouldnt touch anything from intune motorsports. Id contact Tony Bellert Race Engines in Toowoomba. He does a few types of springs that arnt sh*t as he only uses good brands at not bad prices. Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495867 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 25d Gender: Male Location: @ my laptop Posted 28/08/14 11:07 AM Share Posted 28/08/14 11:07 AM Some thing I've quickly thrown together Well quickly copied and pasted from mainline and is posted on our facebook page;) the full version showing dyno graphs is on our facebook book Dyno Torque Figures – “The Truth”On the common types of Chassis Dyno’s we see here in Australia, (Mainline DynoLog or Dyno Dynamics), both of these dyno’s, calculate power at the roller in the same fashion. That is, we measure Roller RPM and Roller Torque and these two variables are used in the traditional Power calculation formula, either metric or imperial, you get the same result: HP (@ roller) = (roller torque ft/lbs x roller rpm)/5252OrkW (@ roller) = (roller torque Nm x roller rpm)/9543When the term Roller Torque is used, this means we are measuring Torque from a Load Cell that is attached in some fashion to the Retarder (Eddy Current Retarder/PAU) that is coupled to the Drive Rollers (the knurled rollers). The Retarder applies a braking force to the Rollers, and since the Retarder Frame is restrained from turning by the Load Cell, the force is transferred into the Load Cell which measures force in typically Kg or pounds force. The length of the arm the Load Cell is attached to is precisely known, so, with force over a given length, we can determine “Torque” in Nm or Ft/lbs.Roller RPM is usually measured by an Inductive speed sensor of some type, or a Shaft Encoder, or in the old days on a Vane Dyno, a Tacho generator.These two inputs are used by the Dynamometer Control System to calculate the Power.Now, because we measure Torque down in the Dyno bed from a device that is coupled to the Roller, ANY gear multiplication, or gear reduction, will influence the Torque measured at the Roller. So some variances that come into the equation are: Torque Converter slip ratio Transmission ratio Differential ratio Tyre size Roller sizeThese variables all influence the Torque as measured at the roller. Some people will then initially think, the lower the gear, the more Torque, so the more Power we will make, THIS IS NOT TRUE.Remember the formula for calculating Power, we have Torque AND RPM, so if we use a lower gear ratio, the corresponding Roller RPM will be reduced by the same factor as the Torque is increased, so we end up with the same power. This is a purely mathematical explanation.The reason some of the confusion happens in regards to Torque (roller torque) on a Chassis Dyno, is there are two common sizes of rollers used on dyno’s here in Australia, those being 219mm or 273mm (these are raw, un-machined sizes).The larger diameter roller will have a higher Torque reading at a given Road Speed, but have a corresponding lower Roller RPM, the torque value increase will be the difference in Roller Diameter, we’ve done the maths for you, and the 273mm roller will have 24.6% more torque.What this means is, a particular car may have 200RWKW, but it may have 500Nm on a 219mm roller, but 623Nm on a 273mm roller.We now need to understand the Torque that gets to the roller, and why it is normally higher than at the Crank. Remember we listed all the things that will influence the Torque at the Roller, Gearbox Ratio, Diff Ratio, Tyre size etc. If we simplify it somewhat, we’ll use a gearbox ratio of 1:1 in the following example, and we are not accounting for driveline loss in this example.Take a traditional LS1, a torque figure of 530Nm is quoted at the crank. If the Gearbox Ratio is 1:1, so we have 530Nm going into the diff, now if we have a diff ratio of 3.46:1 (this is a gear multiplication), we then have 1833Nm at the axles. (Those that have had their cars dyno’d on a Dyna Pack Hub Dyno will be accustomed to these numbers). The next step in the Torque journey is the Tyre to Roller ratio.This is where the Dyno Roller size will affect this value. If we transfer the 1833 axle Nm thru a 650mm tyre to a 219mm roller (this is now a Gear Reduction), this ratio is 1:2.968, so we divide our 1833 by 2.968, gives us 617.58Nm on a 219mm Roller.In the case of a 273mm Roller, our ratio is 650/273 = 2.3809, so we divide the 1833 axle Nm by 2.3809 giving us 769.87Nm roller Torque on our 273mm roller.Remember the larger roller will be doing less rpm at a given road speed, so the same power will be present.To simplify this somewhat, both Dyno manufacturers have a term that makes the differences in Roller sizes a non-issue, this term is Motive Force on a Mainline DynoLog, or Tractive effort on a Dyno Dynamics. Motive Force/Tractive Effort is a Calculation (this where some dyno operators get it wrong, they believe the dyno measures Tractive effort).Motive Force/Tractive Effort is calculated as such, Roller Torque/Roller Radius, so in our example above, we have 617.58Nm / 0.1095metres (radius of 219mm roller) giving us 5640 Newtons (not Newton Metres as Newtons are related to a linear force , Newton Metres are related to a twisting Force). On our large roller, we have 769.87Nm / 0.1365 giving us 5640 Newtons.So a Dyno with 273mm diameter rollers will have Roller Torque figures approximately 24.6% higher than a Dyno with 219mm rollers, but both dyno’s would show the same Power and Motive Force.In order to simplify the Torque values even further, both Dyno Manufactures have what we term “Derived Torque”, which is a calculated value based of RWKW and “EngineRPM”, this calculated “Derived Torque” takes any gear multiplication out of the equation, so one very good way of using Derived Torque is, if you have a particular car that had 3.46 diff gears, and has now been changed to 3.7, the Derived Torque value will not be affected, whereas the Roller Torque will, due to the fact the overall gearing of the car has changed.On a Mainline DynoLog, the user has 4 available RPM signals available to the software for it to Calculate the Derived Torque, Tacho RPM (ie HT lead, injector trigger etc), OBDII Tacho RPM, ECU Serial/CAN Data Stream, or lastly, Derived RPM from the Roller Speed. The first 3 options will provide very accurate Derived Torque values, whereas using Derived RPM (which is based on a ratio of vehicle dashboard tacho against roller speed), will not be very accurate on a Automatic car due to the varying slip ratio of a torque convertor, but will be accurate at whatever point the Derived RPM figure was set. Dyno Dynamics also have a version of Derived Torque; we believe it’s just called RWNm or just Torque Nm on a Graph when printed.While we always suggest that users of our system should use use Derived Torque on a Report given to customers, they can do as they please, and a lot just use and/or print Roller Torque. It only takes a few seconds to choose to display Derived Torque.All of our reports do report Motive Force, so for a comparative point of view to a Dyno Dynamics Dyno Graph, compare the Tractive Effort to Motive Force on a Mainline DynoLog.Now something to remember, the Motive Force or Torque trace, has the exact same shape curve when compared on a similar Graph Scale. Also, the Derived Torque shape will be the same shape as Roller torque for a manual car, but can be quite different and more “manual” car looking for an Automatic car.Another benefit of displaying Derived Torque, that is you are a Horsepower and Foot Pounds of Torque junky, instead of kW and Nm, the Derived Torque and Horsepower will cross at 5252rpm, (just like it does on an Engine Dyno). 8 Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495878 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 4m 24d Gender: Male Location: near brisbane Posted 28/08/14 11:13 AM Author Share Posted 28/08/14 11:13 AM ok thanks for that Matt036 ,but I have just made up my mind to only deal with Ratter from now on .He has helped me out that much that I owe him that .even if they cost more .I cannot expect help for nothing all the time .Will get all parts of him from now on .I trust him more than anyone else to do the right thing by all of us ,so why go anywhere else . I willdefinitely support someone as genuine as him ,so I know what I get works the first time and if not there is after service with a smile . What else can anyone ask for . This may be thestart for me to wake up and listen to people in the know . 2 Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495884 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 25d Gender: Male Location: @ my laptop Posted 28/08/14 11:20 AM Share Posted 28/08/14 11:20 AM thanks mate but you are probably better off buying a set direct from Atomic, it will work out cheaper for you, you've already wasted enough money 1 Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495886 Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 11y 4m 24d Gender: Male Location: near brisbane Posted 28/08/14 11:22 AM Author Share Posted 28/08/14 11:22 AM wow that's to much for me to take in in one go .lol So my power that I thought I had is not all that brilliant due to 3.9 gears changing the roller speed ? Link to comment https://www.fordxr6turbo.com/forum/topic/89003-turbosmart-actuators-are-rubbish/page/13/#findComment-1495888 Share on other sites More sharing options...
