High Pressure Power Steering Line!
LOWXR8
  • Member For: 16y 7m 14d
That's the part number for the nut mate like you asked for not the whole hose assembly I have one of them nuts sitting at home.
  • 8 years later...
  • New Member
  • Member For: 8y 10m 16d
Hi everyone,
I have a 2010 Falcon G6 with this issue.
I bought the nut from Jefferson Ford and have a nut splitter to take the old one off with
https://www.jeffersonfordparts.com.au/new-genuine-ford-ef-el-xh-au-power-steering-hose-f
I am not that good mechanically and cant find a local mechanic that will replace the nut for me so it looks like I am going to be forced to try doing this mysellf.
I don't have access to a workshop and live in an apartment that has off street parking so I will have to try and do it myself there.
My question is would I have to pull the whole pipe off or will just unscrewing it from the power steering unit be enough for me to be able to access the nut, split it, and replace it?
  • Puff
  • Member For: 9y 11m 6d
You can just undo it from the pump and do it that way. I did it successfully with an angle grinder, you'll have no worries at all with a nut splitter.
  • Puff
If you can get it to stop leaking by just swapping an o-ring into it then do that. Mine is different than the one in the video, there is a flare on either end of the nut that holds it in one position.
