boost69 Donating Members 737 Member For: 19y 8m 23d Posted 15/08/14 02:14 AM Share Posted 15/08/14 02:14 AM Guys,The last couple of weeks the transmission on my high mileage BF Mark II XR6T (223,000KMS) has been making a whining noise when cold which goes away after five minutes of driving. (when the car warms up).The transmission was serviced at around 185,000KMS.You guys think it could be an oil issue?...Or does a transmission whine mean that death is imminent.? Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 5m 6d Gender: Male Location: Penrith Posted 15/08/14 08:50 AM Share Posted 15/08/14 08:50 AM Get oil level checked. Mine did it after a service and had it checked and it was 200ml odd low. Once it was topped up slight whine when cold was gone. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 7d Gender: Male Location: Townsville Posted 16/08/14 08:37 AM Share Posted 16/08/14 08:37 AM Does it whine for the whole 5 minutes continuously or is it making the noise when it's nearing a gear change or heavier throttle?The 6sp auto in my F6X has been wharring since I bought it 2yrs ago with 80k kms clock. The car is modified and I have had the gearbox flushed but refilled with Transmax Z It still did it.The only time I got it to almost stop was when I changed the battery for a new one which must have reset the gearbox's learning mode as it was only just making the noise on the odd gear change but came back after a week!I believe the wharr is a pump noise inside the gearbox but can't find enough info on the problem... Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 7m 9d Gender: Male Posted 16/08/14 11:55 AM Share Posted 16/08/14 11:55 AM Refill it. You did swap the filter right? Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 8m 23d Posted 16/08/14 11:57 PM Author Share Posted 16/08/14 11:57 PM (edited) Yeah, I even changed to the metal pan, with separate filter...It just whines through all gears and only stops once the car has warmed up...I suppose I will have to start with looking at the oil levels... Edited 16/08/14 11:58 PM by boost69 Link to comment Share on other sites More sharing options...
VippiN Member 94 Member For: 16y 1m 4d Gender: Male Location: Adelaide, Australia Posted 17/08/14 11:13 PM Share Posted 17/08/14 11:13 PM I didn't have a whine but I did have an issue with my cruise control rpm fluctuating. Only start happening after my trans cooler install. Took the car to my local trans specialist and it drank 700-800ml of life guard. No more issues after that - So it shows how sensitive they are when not full. 1 Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 6m 5d Gender: Male Location: Adelaide Posted 17/08/14 11:44 PM Share Posted 17/08/14 11:44 PM ^^^ mine does that to. mihht have to get it checked out. Link to comment Share on other sites More sharing options...
VippiN Member 94 Member For: 16y 1m 4d Gender: Male Location: Adelaide, Australia Posted 18/08/14 02:28 AM Share Posted 18/08/14 02:28 AM You're in Adelaide, I went here if that helps - https://www.facebook.com/mnautos?fref=ts Link to comment Share on other sites More sharing options...
