  • Member For: 22y 2m 2d
Don't know where the dyno prints are ATM but this shows 481 rwhp in 2002.
All tooned by me Jet when we didn't have the internet and no dyno.
I started with a carby draw thru setup in 1995 that maxed out at about 300rwhp.
Changed to fuel injection about 1997 and immediately went 400rwhp, same engine.
Its basically remained the same since 1997, just more boost and a change to a copper head gasket.
Has done 512rwhp on another dyno at 23psi boost. Timing at max boost/revs --- 28degrees would you believe
I had to scan photos, We didn't have digital cameras back then.
Notice Yella Terra Alloy head.
Also it had a Mack Truck Garrett Bar and Plate Intercooler that was cut down to fit behind the grill. Its a real sleeper. I got it for free as it was bent in an accident but you couldn't buy cheap intercoolers back then. It was like $2000 back in the late 90s for a custom intercooler and $500 for and 044 fuel pump. That was alot of money back then.
  • Like 2
  • Moar Powar Babeh
  • Member For: 19y 8m 9d
Yeah what a crap time we live in. 500rwhp is the norm and ford sell factory turbo and supercharged cars.
  • Like 3
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 1d
Cool stuff tony
Big hp for the old 6 back then mate, still quite good today. U still got the bird ?
Yeh, still got it, drivable and licensed. Needs brakes and a few other things done.
I reckon 1000rwhp now is the old 500rwhp. Getting married and kids has put a stop to heavily modifying cars for the last 10 years but planning to resume the passion.
Very true that mate
That alloy terra head would of been a few coins also
What injection did u go ? Rochester mech ?
I got the Yella Terra head quite cheap. $1200 at the time when they just came out. I put probably 30-40 hours of porting ports,chambers and inlet manifold and whilst I was relatively green to porting back then, I would still take the meat out where I did looking back.
I used an EMS duel sport with wide band lambda built it, Lucas 550cc injectors, bosch 044, VK fuel injection manifold and a steam pipe turbo manifold I TIGed up.
I did upgrade to the EMS 8860 when that came out which has the ability to give you an average of the airfuel ratio for each load point. Its the best feature when tuning.
Alot of work in that engine. I have tried to break it (not relentlessly but many hard KM at high RPM) but the HQ racing pistons nor blue motor rods (preped with ARP bolts) never let go. An aluminium flywheel and heavy B&M balancer really helped the harmonics in the crank dept.
I have always been a fan of the straight 6 and one reason why I like the falcon 6 so much. Very easy engines to work on and get good power from.
