  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 26d
So much giggle
Where the fook is my mod badge anyway u pelicans !
  • Member For: 10y 11m 19d
  On 11/08/2014 at 2:49 PM, turbotrana said:
What do you want to do mate. Do you want to learn how to tune and become a guru like Jet Tooner
I just want to be an original gangsta
Well pick another state cause I got this chit all wrapped up here in sa ;)
  • loitering with intent
  • Member For: 21y 9m 8d
  On 11/08/2014 at 9:16 PM, JETURBO said:
So much giggle
like' yeah. WTF
  • Member For: 14y 7m 8d
  On 11/08/2014 at 12:29 PM, Ralph Wiggum said:
I thought as I mod I was quite helpful..? Hpt can tune zf trans and can also read/write over sct tunes.
  On 11/08/2014 at 1:39 PM, Ralph Wiggum said:
Correct.
Edit, not entirely correct. SCT requires the tuner to build the tune from the ground up (or from a base file) SCT tuners cannot view other tuners tunes without jumping through some hoops via hettods/sct
Hpt can read and modify hpt tunes or sct tunes once the Tune is licensed.
I was told the zf tune was available for B series but not FG yet. Not sure what the difference would be but just going off what I'm told
So if I was to get a retune with HP, the tuner can unlock my SCT tune and modify it with the xcal device?
Trying to see whether its possible to retune using HP but keeping xcal to have multiple tunes. I thought the car might have to be returned to stock every time to load a new tune in and the device would run out of unlocks
  • Moar Powar Babeh
  • Member For: 19y 8m 4d
Fg was supported before b series. Possible your source got that arse about.
You could read the custom tune from return the car to stock, save the stock file with HPT and then reflash the hpt modded tune as a stock tune into the xcal.
Helluva lot of stuffing around tho. Trans can be flashed direct.
Surely that would take less than a few minutes?
It is like 3 different steps with two different pieces of software, wouldn't an oil change take longer?
Edited by Dagabond
quote removed
