  • Member For: 14y 9m 24d
I've tried searching the forum and online generally on how to replace the fuel pump but can't find any info on how to remove the pump from the white assy it sits in. I pulled the pump assy out but can't see any way of splitting the inner and outer halves, the 2 spring loaded rods stop it from being disassembled.
Has anyone been able to do this and if so share on how it's done?
https://www.fordxr6turbo.com/forum/topic/88915-fg-f6-fuel-pump-replacement/
  • Member For: 13y 5m 1d
Did mine a few days ago. I had a replacement fuel hose going from the pump so I cut that off and it gave me enough movement to split the upper and lower halves. The inner and outer should come apart pretty easily though. Don't be afraid to use a bit of muscle is all I can say
