rollex Member 683 Member For: 10y 11m 22d Gender: Male Location: Australia Posted 10/02/15 01:08 AM Author Share Posted 10/02/15 01:08 AM (edited) Bruce is happy to help and said he would look at if I wanted however I'm still going to get KPM to do the tune.I'll post up the two dyno graphs later today. For reference bruces was 340rwkw and about 0.5-0.75 lower AFR, KPMs was 310rwkw and never went lower than 12.5 AFR and as high as 13 AFR at peak torque.edit: Motor is breathing slighly now, was oil in the intake after 3 months (new intercooler so it was all clean before 3 months). It also used maybe 500-1000ml of oil in 3,000kms, in fairness the motor does have 190,000 kms on it. Before the tune it didn't drink any oil.How much oil do these motors tend to use in their later life? Edited 10/02/15 01:13 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529057 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 7d Gender: Male Location: Perth Posted 10/02/15 01:39 AM Share Posted 10/02/15 01:39 AM What intake setup is on it? Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529061 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 22d Gender: Male Location: Australia Posted 10/02/15 01:59 AM Author Share Posted 10/02/15 01:59 AM (edited) Stock everything with a process west stage 2 intercooler and a K&N panel filter. I know some cars tend to get too much oil in the head if they sustain high revs and need oil restrictors/extra drains etc, I'm assuming this isn't a problem with the barra and that any oil in the intake is from piston blow by?Using this kit:http://www.processwest.com.au/products/ford/ba-bf-products/stage-2-intercooler Edited 10/02/15 02:00 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529064 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 7d Gender: Male Location: Perth Posted 10/02/15 02:02 AM Share Posted 10/02/15 02:02 AM No so much blow by, More a a case of stock PCV and Cranck Case ventilation system was designed for an NA car. Whats you peak boost pressure? A decent check valve and catch can on the PCV line works wonders Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529065 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 29d Gender: Male Location: Adelaide Posted 10/02/15 02:14 AM Share Posted 10/02/15 02:14 AM ^^^ What luke said ^^^Think about where you want to take your car for a minute If they are prepared to keep on the loud pedal to 13.0AFR "because its not their tune" you have to question their "care factor" to begin with Food for thought !We had many cars come in that were "to lean" in our opinions and not one run was complete on our dyno until it was adressed ! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529069 Share on other sites More sharing options...
BenDoCo I'm getten too old for this s**t Bronze Donating Members 4,509 Member For: 12y 1m 23d Gender: Male Location: A big bridge over a river in South Australia Posted 10/02/15 02:18 AM Share Posted 10/02/15 02:18 AM ^^^ this is why I love reading either from the owner or the tuner - "the run was terminated".Proves to me the a tuner cares about the car. Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529072 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 22d Gender: Male Location: Australia Posted 10/02/15 02:18 AM Author Share Posted 10/02/15 02:18 AM (edited) On 10/02/2015 at 2:02 AM, Ralph Wiggum said: No so much blow by, More a a case of stock PCV and Cranck Case ventilation system was designed for an NA car. Whats you peak boost pressure? A decent check valve and catch can on the PCV line works wonders~15psi that tapers off to maybe 12psi. Are you saying the oil in the intake may purely be because of limitations of the stock PCV system at these boost pressures? On 10/02/2015 at 2:18 AM, BenDoCo said: ^^^ this is why I love reading either from the owner or the tuner - "the run was terminated".Proves to me the a tuner cares about the car. That is pretty much happened, they said don't get it on boost until it can be retuned. Edited 10/02/15 02:20 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529073 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 7d Gender: Male Location: Perth Posted 10/02/15 02:21 AM Share Posted 10/02/15 02:21 AM Yes, stock pcv check valve is ineffective at those sort or pressure, it allows boost pressure into the crankcase and this forces oil mist out the crankcase vent. A can on both is best, otherwise a check valve to prevent boost pressure entering the crankcase and a can on the pcv is a must imho Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529074 Share on other sites More sharing options...
rollex Member 683 Member For: 10y 11m 22d Gender: Male Location: Australia Posted 10/02/15 02:22 AM Author Share Posted 10/02/15 02:22 AM (edited) I'll look at getting a check valve for the vent, where on the rocker cover is the vent located? Also does the PCV leak with old age, worth replacing this as well? Edited 10/02/15 02:24 AM by rollex Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529075 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 7d Gender: Male Location: Perth Posted 10/02/15 02:27 AM Share Posted 10/02/15 02:27 AM Pcv is the lh rear fitting, the crankcase vent is the fittings in the middle and has a short plastic pipe that connects to the cross over. No point changing the stock pcv valve if you fit another in line Link to comment https://www.fordxr6turbo.com/forum/topic/88876-bf-injectors-with-good-spray-pattern-for-300-350rwkw/page/7/#findComment-1529077 Share on other sites More sharing options...
