rollex Member 683 Member For: 10y 5m Gender: Male Location: Australia Posted 25/08/14 03:39 AM Author Share Posted 25/08/14 03:39 AM Ok got it stay away from rapid, do any of those kits not requiring cutting?Another question how do these motors go in summer, do they run hot or have cooling issues with standard radiator? If tuned correctly can you still give it stick on a 30c day without worrying about doing a head gasket/over heating?My skyline used to get a beating on days seeing up to 40c without issues but I know this is not always the case so just want to be prepared. Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 6m 4d Gender: Male Location: Central Coast Posted 25/08/14 04:09 AM Share Posted 25/08/14 04:09 AM I went to the drags on a 35 degree day and did consistent high 11s Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 11m 15d Gender: Male Location: Probably above atmospheric pressure Posted 25/08/14 06:27 AM Share Posted 25/08/14 06:27 AM (edited) Have towed a furniture trailer up hills @110km/h on a 35° day with tuned car and cooler thermostat than factory, stock radiator, being mean I got the oil to about 110-115° but taking it easy it was fine. Edited 25/08/14 06:28 AM by -Stever- Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 5m Gender: Male Location: Australia Posted 25/08/14 06:43 AM Author Share Posted 25/08/14 06:43 AM oil to 115c is asking for trouble! Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 16y 11m 15d Gender: Male Location: Probably above atmospheric pressure Posted 25/08/14 12:49 PM Share Posted 25/08/14 12:49 PM (edited) Yeah I chilled out when I saw that. Coolant was about 2/3 I think. Just another reason why I had no friction material left in some of the ZF clutch packs at the 200,000km box rebuild hahaha Edited 25/08/14 12:50 PM by -Stever- Link to comment Share on other sites More sharing options...
BRK Member 361 Member For: 12y 10m 26d Gender: Male Location: Perth Posted 26/08/14 01:01 AM Share Posted 26/08/14 01:01 AM +1 for process west gear. Service is excellent. ( Plazmaman, same. ) PW stage 1 kit is a pretty simple fit and mine required no cutting. I like it because you still have the factory cross-over so it looks "stock" for the roadsides.Fuel pump is a must and there are good drop in kits now. ID1000's or KPM for injectors. The large injectors work really well.The stock cooling systems on these cars are pretty good unless you want to beat the hell out of it on 40+ degree days - and if you do, there are improved cores available. I think PWR do one and I know a custom alloy unit can be had in WA for under a grand ( sounds a lot - but what was being offered was top shelf)Waste gate porting - this one always seems to be a vote either way. You will go over 300 at the treads with the stock waste gate but by how much is the question. 320?Weight. A BF manual with 1/3 tank of fuel and spare etc in it went ~1650 KG on the weighbridge at the tip.Clutch - I use the option 3+ Ace version and like it.Anything with 160,000 + k's on it is going to need a good look. If you have to do the valve springs it is time consuming and maybe at 160+ . . . .might be worth doing.Bux. the clutch and cooler will run ~3500 with freight. Injectors..750? Pump 300 -500 ( depends on the kit you buy). We are at ~5K now and have not touched the exhaust, air box, valve springs or waste gate. Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 5m Gender: Male Location: Australia Posted 26/08/14 01:22 AM Author Share Posted 26/08/14 01:22 AM (edited) Thanks for that post, the stage 1 vs 2 intercooler kits, is there going to be much difference in performance between the two? Edited 26/08/14 01:28 AM by rollex Link to comment Share on other sites More sharing options...
BRK Member 361 Member For: 12y 10m 26d Gender: Male Location: Perth Posted 26/08/14 04:31 AM Share Posted 26/08/14 04:31 AM The core on the stage two kit is larger 500 x 360 x 80 versus 420 x 360 x 90 and you lose the under battery pipe which gets a lot of criticism for restriction along with some of the length of the stock intake tract. It looks logical to me that the stage 2 kit offers better performance. Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 5m Gender: Male Location: Australia Posted 26/08/14 05:05 AM Author Share Posted 26/08/14 05:05 AM (edited) Yeah I guess the question is at what point would the smaller 420mm one no longer be efficient, the plazmaman website says their 500x350 one is good for over 380rwkw where as the 470 is good for up to 380 so it sounds like it would be fine for up to 350 which is about all I think I ever will want.The over the bonnet cross over pipe definitely makes it look far more modified though, $1680 vs $1k, not sure if it would be worth it. I've already got a K&N filter on the stock airbox, at what point does this become a restriction?http://www.processwest.com.au/products/ford/ba-bf-products/stage-1-intercoolerhttp://www.processwest.com.au/products/ford/ba-bf-products/stage-2-intercooler Edited 26/08/14 05:06 AM by rollex Link to comment Share on other sites More sharing options...
rollex Member 683 Member For: 10y 5m Gender: Male Location: Australia Posted 26/08/14 05:14 AM Author Share Posted 26/08/14 05:14 AM (edited) Hmm, this kit looks like it would be better value, routes the piping much nicer and is 500 x 400 x 90 vs 500 x 360 x 80 for $1600 though I don't know if it is necessary for the power goal I havehttps://plazmaman.com/shop_itemdetail.php?itemid=280&cate=67 Edited 26/08/14 05:20 AM by rollex Link to comment Share on other sites More sharing options...
