Easy 300Plus
ramp rate
  • Member For: 10y 7m 4d
yeah thank gunna,I was just as surprised when it rolled out that number also,we destroyed the flex plate on its 2nd power run at 330,put atomic plate in ran it at same tune spat out 344 so we have let it sit there.as mentioned prior will throw another 5psi at it once new engine is ready to drop in and see what it spits out and keep upping the boost till it pops.
spent 6500 on bottom end,scott from TUFF TUNE THRU SPANNERS,using current head with atomic cams and gears,6boost manifold precision gate currently waiting on new precision 6267 turbo.all up new combo including fmic upgrade,fuel system upgrade turn key minus gear box 12500,will be good for safe 450rwkw safely good for 550rwkw if we ever want to push it.
  • MattyP
  • Cruise Control
  • Member For: 12y 9m 27d
I gotta ask bud
But what's the reason on going a 6 boost and 6267 when precision have the 6235 or 6466 internal gate?
I'm genuinely curious as I'm eventually looking at upgrading down the track.
  • Member For: 11y 1m 3d
6 boost make manifolds
If you every see a 6t with a turbo right up by the rocker cover usually it's a 6boost
thanks for the info .,this is only the second turbo car I have owned .last car about 23 years ago .so I am not to smart with it all .but this forum has helped a lot .still getting there
