Peppy's Build Thread
  • Member For: 11y 10m 11d
Mainly nulon 20-50 full synthetic... I'm starting to think that J@t is onto something when he says ford recommend mineral oil for a reason in these engines
  • Member For: 21y 10m 14d
Its got nothing to do with the oil. Your bearings have normal heavy load wear, not that bad. The ring lands on the cast stock piston are simply not designed for the loads we put on them. They will do that.
However that cam wear is a bit of a concern.
I was more concerned about the cam wear, there's also some signs of wear on the head from the cams... Might not be getting quite enough oil, or the wrong oil is going used, or the high spring pressure is causing excessive wear
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 13d
Whose this J@T bloke lol what would he know hahaha
Wow joe for all that was wrong with it ya gotta hand it to ford for making a stocker stay together that well
Cracked ring lands is common with RB's and advanced timing ..... Could be something here but the stock ford piston is actually quite a good unit
I can only imagine what my rotating assembly looks like also after learning to tune lol ;)
Bent rod is a nice touch to ...... It does "seem" like the crow set has this flaw but as you said its been brought up many times now by many tune shops
Nice to see piks in your threads keep it up :)
  • Member For: 10y 9m 11d
Wow all that damage and the engine still hanging together .
It might be wise to freshen up those valve springs while your in there.
Just out of curiosity why wouldn't you go for a after market inlet manifold?
Is it cost ( I know we're not all made of money) or their not worth it at that power level.
It just seems your going to a lot of trouble with head mods and the standard inlet sounds like a problem.
I still don't get this cam wear prob, after all they are rollers, wouldn't think they need much lube regardless of oil type.
Great read and good luck with it all, cheers!
Edited by "Captain Retard"
Definitely credit to the engineers
The springs are only a year or so old... I have a spring tester so I'll see how their going, and go from their..
Yea mainly cost, but essentially this is just a stepping stone setup... my real goal is to do a de-stroked monster haha, but being a young guy looking to buy a house, get married etc it's not realistic right now...
I've set a budget of $10-12k this is a really tight budget and most people getting this list of mods done through a shop would be looking at double that, it's all I can afford, so I'm trying to get the main components done and I can later add bolt ons like a manifold
The fg manifold only flows slighty higher but has a lot more even flow
  • Like 2
