  • Bronze Donating Members
  • Member For: 12y 2m 28d
Oath they do... well mine does anyway
  • Member For: 12y 3m 2d
Hmm the ulx stuff is hard to find around here, I'll have another look around tomorrow..
Everything else came today, ohh how exciting, everything is so pretty, the shafts, hubs, studs, trutrac, bearings, seals and a set of various shims just for variety
I just opened and checked everything, tidied up abit, everything's there, just need some oil and new wheel nuts as the new wheel studs are longer..
Now installing the twin bush setup, it's pretty straight forward, and the instructions are thorough, I set it up with the empty housing, lots of measurements and levelling, to make sure it's all sitting true and keeps the correct pinion angle, a few tacks while everything is installed then remove the diff and hat to finish it off, a coat of paint and all good..
A quick check to make sure nothing moved
And see how much more we can get done tomorrow!
Edited by Peppy_t92
  • Like 4
  • Member For: 11y 7m 2d
Was about to comment on that to lol. Looks cold as f and porosity for dayyyys
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 1m 4d
Mehh I can't weld for chit either, if it sticks it's a weld ;)
  • Like 2
Got a boiler maker mate to come past and have a look at my weld job on the cradle.. After he had a good laugh at my expense, he said it will be fine, suggested a couple spots that could use some more and sorted it out..
I got some pics of the stripped centre all cleaned up and ready to start going back together
Pressing the old hubs and bearings out was interesting, I read up abit on it and everyone says what a pain it is.. I soaked it in wd40 and made up a tool/jig for my little hand held press, pretty proud of my efforts as it took all of 5 mins to remove the hubs
It split the bearing in half in the process but it was easy enough to bash the casing out
I picked up the last couple of items today, some open wheel nuts for the longer studs and some redline gear oil
Hopefully it it all built tomorrow and install the cradle Thursday!
Edited by Peppy_t92
  • Like 2
