Peppy's Build Thread
  • Member For: 21y 5m 2d
All these karnts jumping on my potential buys! Sheesh...
Anyone got pics of both exh housings side by side? I can't ever see my Territory reaching these power limits so it's not a biggy that you all steal my glory!!!
Think I found a page with the two different housings-
http://performanceforums.com/forums/showthread.php?67252397-Custom-Standard-Position-Exhaust-Manifold-Suit-6cyl-Falcon-BA-BF-FG-amp-FPV-models
Edited by bjc
  • Member For: 11y 10m 3d
Well I either broke the diff bolt, or the diff hat, the bolts hanging out, and there's lots of oil spread over the diff.. I havnt stuck my head right under yet
So a built diff, cv's and probably the independent Motorsport dual bush setup is next on the cards -_-
Those would be my picks, all capable of ~1000hp Not sure how the ZF will like it.... Anyway that's just a dream at this stage... I'll focus on the 9's with this setup for now
Bjc that is a nice manifold, bit pricey, but I might look into it... If I do that, I'd probably want a nice twin gate setup for those "street" like surfaces... Something to think about anyway
Ralphy, I'm going to grab that FG manifold off 747, if I change my mind I'll send it your way
That link mate was more just to show the difference between the BA and FG series exhaust manifolds. I'd probably look into the 6boost manifold if you're going that route but not sure if he does custom setups or not?
  • Member For: 12y 24d
Peppy, I have been testing this with bugsy on the HP Tuners forum but I have been able to get the 4 bar t-MAP and boost sensor working. Its not perfect because I cannot change the actual sensor data but we have a tune with boost control in the range 28-32psi, AFRs matching commanded and the car drives just like it does with the standard sensors (perfect). Timing is following the load values from 2.5 to 3.2+. Still early days but send me an email if you are interested. BTW 4 bar is the better sensor for this conversion.
Thanks Darryl, sounds like it's working better then expected! Once I get my diff sorted I will look at buying a couple of 4bar sensors.. At this stage the 21psi tune is still within the limits of the std sensor, but once I re-torque the head it will be ready for more, so that will come in handy.. It's good to see people trying things outside of the square!
No chance 747, the re-torquing is just to tighten everything back down as everything has now settled, I'll get the larger washers from atomic, which should help with their clamping force
