JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 30d Gender: Male Location: Adelaide Posted 10/07/15 10:57 AM Share Posted 10/07/15 10:57 AM Mine does skids but doubtful it will get out of first let alone top gear hahahaha Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 9m 27d Gender: Male Location: Liverpool Posted 13/07/15 09:55 PM Author Share Posted 13/07/15 09:55 PM (edited) Need to tune it bellbatI went on the forum cruise over the weekend, it was a good day out and probably the longest single drive the car has been on since the build... The car performed flawlessly! (Almost) with the only issue being that one of the cooler clamps came off... Non issue really, I have bought a heap of clamps from a truck spare parts shop, they are wider and have an extra loop around, so I'll double them up on every join and hopefully I'll never have an issue with them againAs for everything else, I'm extremely happy, using the gears through the mountain were good, part throttle and wot up shifts as commanded every time and even down shifts/engine breaking worked a treat... I actually got 160km out of about 3/8 tank of fuel as the first part of the cruise was quite tame, but the way home stuffed that right up, using more then half tank in the 100km freeway drive home... But to be fair, there were quite a few 4-5 WOT moments, (120-260ish) it got the commanded timing, commanded lambda and was holding 28psi ... the box held that like a champ aswell My 2 week old tyres are on the "unroadworthy" side from afew spirited moments on the cruise, which somehow happen every time I drive the frigen thing, I just can't help myself... But I have a few decisions to make, throw some more cheap245/35/19's on or fit some 265/35/19 on these rims, or track down some 9/9.5" GT 335 wheels and put some decent rubber on them... But if I do that there's more chance of the rear end failing, which I can't afford right now.... HmmmmThanks guys Edited 13/07/15 09:57 PM by Peppy_t92 3 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,181 Member For: 16y 9m 20d Gender: Male Location: Melbourne Posted 13/07/15 11:35 PM Share Posted 13/07/15 11:35 PM whilst retaining traction is a good idea, sometimes you just have to save those diff bushes and create smoke from tyres instead haha Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 8m 26d Gender: Male Location: Central Coast Posted 14/07/15 01:09 AM Share Posted 14/07/15 01:09 AM If you sell your gt copies ill take em! Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 10m Gender: Male Posted 14/07/15 05:26 AM Share Posted 14/07/15 05:26 AM Peppy , is there a chance of you doing a trans tuning tutorial outlining what tables you changed and why?. Even along with a copy of your tune would be good but a tutorial would help most.A quote from a Nizpro article. " We calibrate the TCU for extra apply and clutch holding pressures, shorten full throttle up shift times whilst adjusting torque reduction strategies" Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 9m 27d Gender: Male Location: Liverpool Posted 15/07/15 02:13 AM Author Share Posted 15/07/15 02:13 AM I'm definitely not going to do a tutorial Trana as I'm merely changing things that make sense for me to change, I have only made very small adjustments so far... if you look through the tune a few things should stand out, actually that article you mentioned has a few big tips to point you in the right direction.. PM me your number, or something and we can have a chat if you like 1 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 8m 26d Gender: Male Location: Central Coast Posted 15/07/15 02:56 AM Share Posted 15/07/15 02:56 AM Do you still have torque reduction on? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 7d Gender: Male Location: Perth Posted 17/07/15 10:01 AM Share Posted 17/07/15 10:01 AM My response to your question on HPT ForumPep, Im convinced there is a flash counter on the ZF. I find after around 30 writes this happens.Do a read entire and then try to flash it. Link to comment Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 11y 9m 27d Gender: Male Location: Liverpool Posted 31/07/15 03:19 PM Author Share Posted 31/07/15 03:19 PM https://vimeo.com/135057170I know it's been a while, but after a few hours on the dyno, I found a happy place... I'll do a full write up tomorrow.. But for now, I'm leaving it at 448kw @ 5500rpm and 1000nm from 3500-6000rpm!! 6 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,181 Member For: 16y 9m 20d Gender: Male Location: Melbourne Posted 31/07/15 03:54 PM Share Posted 31/07/15 03:54 PM Looks the goods mate Link to comment Share on other sites More sharing options...
