Peppy's Build Thread
  • Member For: 17y 4m 17d
Joe if your interested in hearing some other options
Give this guy a ring, when I was looking around for a shaft he was on the phone to me for about 30 mins also
Had a few different options for our cars, very helpful and was willing to share ideas with me when I rang
He builds the shafts for 5 different V8 supercar teams, I'm not sure what size uni's on the V8 supercar shaft, but he did use the same uni's on the shaft he built for me
I know he is in Melbourne but may be worth a chat
  • Member For: 12y 4d
I was going to ring around some more tomorrow Wilko so thanks for that... Sometimes I worry about getting to many "opinions" but it's just a piece of steel at the end of the day haha..
Ohh and I want to put a tail shaft loop around each shaft!
  • Bronze Donating Members
  • Member For: 12y 2m 13d
What diff bushes are you running ? The firmer the better if you plan on running a uni instead of a cv .
I ended up going back to the standard cv as I didn't like the vibration I was getting under load with the uni . My cars an fg running superpro comfort bushes.
Fair call, I put comfort front diff bushes, with a sports rear diff bush and sports blade bushes..
It will all depend on prices I get tomorrow
Have you thought about a carbon fibre one piece with a cv ? , I'd probably go that way if I done it again.
Loving the build mate .
Edited by LU82
  • Spooling Member
  • Member For: 13y 4m 1d
I have a Gibson 1000hp shaft and Superpro HD bushes, no issues.
Although NVH may just be drowned out by the rest of the setup haha.
Edited by TomT
Thanks 20pounds, initially I didn't re-flash it, it shifted strange 2-3 and flared slightly into 4th... 4th came good after about 300km and 2-3 shift came good around 750km.. I did re-flash the TCM a couple of times throughout the process but that was just to help the adaptive memory, as I assume it was correcting for the massive loss of friction material before the build, the two overdrive packs were 4mm and 5mm over the recommended clearance from memory
I also ordered my Gibson 1000hp shaft, I have decided to just run what he recommended with the two uni's, the Porsche cv is going to be expensive to fit and also replace if it ever come to it, where a uni is cheap and easy to replace.. Chris also said since he has bought his new automatic balancer and people have been taking the time to shim the centre bearing correctly it has been 100% positive feedback, so we'll see how it goes
Thanks Joe
  • Like 2
  • Member For: 11y 9m 9d
I am a bit surprised at the threads I have seen about aftermarket drive shafts having vibration problems.
I would have thought that the places that do them know what they are doing and there would not be issues.
Is there anything that makes them somehow more difficult to get right on a falcon?
  • Member For: 11y 4m 18d
Does seem odd, the guys that are known for doing these cars have a bit to answer for I think.
Gunna(used all his luck on this occasion) used some rando on the sunny coast that hadn't even done a falcon before, usually does heavy machinery. It was spot on first time and cost significantly less than what some are asking...looked the goods as well, used a v8sc spec uni or something
I should add though if the shafts in question aren't being correctly installed by a third party then the shop that made it is hardly to blame..
Edited by barnz
