Peppy_t92 Silver Donating Members 748 Member For: 12y 28d Gender: Male Location: Liverpool Posted 25/05/15 11:13 AM Author Share Posted 25/05/15 11:13 AM Thanks guys, I really am over the moon..The box is definitely firm, but not in an annoying way, it's not harsh, but firm... It's still the standard tune and held Powerplay well, baked 2-3 on every straight, every lap haha then that video was 2-3-4 from 80km starting on the brake... Initially 2-3 and 3-4 had a strange shift, as if it loses pressure slightly while changing then grabs gear, if that makes sense... Funnily enough after Powerplay 3-4 cleared up but it still does it 2-3 under light throttle, but 1/2 throttle and up its fine... So theres a procedure I want to do, flashing it a couple times, to speed up the adaptive memory and hope for the best... It's pretty baby a good idea to do the clutches first then do the zip kit later to see what sort of a difference each one makes..The issue with the coupling is that the sleeves inside the bushes aren't long enough, so the washers/bolts push against it crushing the bush before you even drive it... If those sleeves were longer they would probably badly work, but I've lost intest.. Im also removing the engine mounts and putting std ones back in, there's an annoying vibration when idling in gear, and I believe they may be taller which is what's causing my cats to sit so close the the body..Mates hoyst is at a mechanical shop so, nothing too exciting there..I really can't wait to turn her up, just going to drive it like this to sort out the box and there's still a few things I want to do like, drop the oil in the box, install the Niz alloy pan, and install a spark booster... I also have a sneaky suspicion that my diff us on its way... Bloody typicalThanks guys 3 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546084 Share on other sites More sharing options...
Seaton Donating Members 537 Member For: 12y 8m 3d Gender: Male Location: Sydney Posted 25/05/15 11:13 PM Share Posted 25/05/15 11:13 PM Did you get the Niz pan yet? I got a price on one a bit back, very expensive. But it's ideal being alloy with fins and a drain plug. Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546125 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 28d Gender: Male Location: Liverpool Posted 25/05/15 11:29 PM Author Share Posted 25/05/15 11:29 PM On 25/05/2015 at 11:13 PM, Seaton said: Did you get the Niz pan yet? I got a price on one a bit back, very expensive. But it's ideal being alloy with fins and a drain plug.I ordered it at the same time as the shaft, they said ther was a couple week wait as it had to be made.. I have since run out of money, but will definitely be getting it, $900 odd iirc.. The street version has 2L higher capacity, and yea being made of alloy with the fins will all help with cooling, and will assist with hard launches at the track eventually, to avoid fluid cavitation Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546130 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 10d Gender: Male Location: Brisbane Posted 26/05/15 04:01 AM Share Posted 26/05/15 04:01 AM (edited) The engine mounts is a harmonics thing, think Ralph had a play around with the idle on his and found a sweet spot.So yeah even different engine mounts require a tune lol Edited 26/05/15 04:03 AM by barnz 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546171 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 28d Gender: Male Location: Liverpool Posted 27/05/15 01:14 PM Author Share Posted 27/05/15 01:14 PM Some more running in footage https://vimeo.com/128987989 https://vimeo.com/128988159 5 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546476 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,452 Member For: 17y 20d Gender: Male Location: Melbourne Posted 27/05/15 01:25 PM Share Posted 27/05/15 01:25 PM love the running in method Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546477 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 9m 29d Gender: Male Posted 27/05/15 01:56 PM Share Posted 27/05/15 01:56 PM f*ck me that thing runs strong! Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546481 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 5m 10d Gender: Male Location: Brisbane Posted 28/05/15 07:14 AM Share Posted 28/05/15 07:14 AM Are the links broken for anybody else? Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546583 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 11m 29d Gender: Male Location: Western Sydney Posted 28/05/15 07:34 AM Share Posted 28/05/15 07:34 AM ^^ Yea, can't watch them. Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546588 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,452 Member For: 17y 20d Gender: Male Location: Melbourne Posted 28/05/15 07:36 AM Share Posted 28/05/15 07:36 AM because they are hosted on vimeo, they probably don't work on mobile devices without flash capability.Give it a try on a PC Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/37/#findComment-1546589 Share on other sites More sharing options...
