turbotrana Member 2,586 Member For: 22y 1m Gender: Male Posted 18/05/15 10:56 AM Share Posted 18/05/15 10:56 AM What did you do on the head gasket sealing side. Looks like you used some white sealant. Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545030 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 27d Gender: Male Location: Liverpool Posted 18/05/15 09:31 PM Author Share Posted 18/05/15 09:31 PM It was a big night last night, I got the motor/box in and most of the accessories, and spread out the wiring loom... I put it in with both manifolds on, all the accessory brackets, engine mounts, sensors, turbo feed and returns, and heater pipes..Before putting the rocker cover on we primed the motor with oil... Dad modified an old gas cylinder, you pour all the engine oil in, tap into one of the oil holes (I used where the turbo feed connects to) then connect up some compressed air and open the valve!... I didn't film it bud it's awesome to see and hear the oil come out off all the oiling holes, obviously turning the engine slowly as you go, the lifters pump up, and it gets oil through the whole engine, then we just pumped the extra oil over the camsRalphy and Tranna were right about it being tight, but we got it in... The rear end up about 300-400mm and the front about 200mm... The back of the rocker cover fouls on the fire wall, the sump then the balancer touch on the front radiatior sill, and the bottom of the box touches the crossmember haha... By putting a jack under the crossmember, and dropping it gave enough clearance to go in on more of an angle to clear everything... If you leave the rocker cover off it will probably make things easier again, and radiator out... Support the back of the box with another jack and creep it back as you lower the motor...Easy yea? I didn't take any helpful photos if the install, so hopefully my description makes sensehttps://vimeo.com/128194250 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545065 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 27d Gender: Male Location: Liverpool Posted 18/05/15 09:35 PM Author Share Posted 18/05/15 09:35 PM On 18/05/2015 at 10:56 AM, turbotrana said: What did you do on the head gasket sealing side. Looks like you used some white sealant.The machinist recommended Threebond White, We applied a liberal amount to both sides of the gasket.. see how it goes Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545066 Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 5m 9d Gender: Male Location: Melbourne Posted 18/05/15 10:16 PM Share Posted 18/05/15 10:16 PM Are you running it in on a mineral oil ? Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545070 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 27d Gender: Male Location: Liverpool Posted 18/05/15 10:36 PM Author Share Posted 18/05/15 10:36 PM On 18/05/2015 at 10:16 PM, Wilko16 said: Are you running it in on a mineral oil ?Yea, I believe it is mineral, I'm using Joe Gibbs Break in oil, recommended for no more then 500kmStill deciding what I'll run after that, I want to steer clear of any full synthetic stuff 2 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545073 Share on other sites More sharing options...
xr6tForMe Donating Members 275 Member For: 11y 10m 1d Gender: Male Posted 18/05/15 10:42 PM Share Posted 18/05/15 10:42 PM Excellent stuff Joe! Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545074 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 30d Gender: Male Location: Adelaide Posted 19/05/15 12:18 AM Share Posted 19/05/15 12:18 AM Ulx110 mate 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545092 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 14d Gender: Male Posted 19/05/15 01:20 AM Share Posted 19/05/15 01:20 AM On 18/05/2015 at 10:36 PM, Peppy_t92 said: Yea, I believe it is mineral, I'm using Joe Gibbs Break in oil, recommended for no more then 500kmStill deciding what I'll run after that, I want to steer clear of any full synthetic stuffAny reason why you don't want to use Synthetic oil Joe? Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545107 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 27d Gender: Male Location: Liverpool Posted 19/05/15 01:32 AM Author Share Posted 19/05/15 01:32 AM On 19/05/2015 at 1:20 AM, rednose said: Any reason why you don't want to use Synthetic oil Joe?Ford recommend a Mineral 15w-40 oil for std applications, speaking with dad he seems to think that synthetic oils aren't the best for roller rocker applications as it tends to cause the roller to slide or rub rather then roll... Then again the coyotes and 5,4's also run roller rockers yet full synthetic is recommended for them, so I really don't know the theory behind it... But after the wear on my cams I'm willing to try something different just for my own research purposes.. I was using Nulon 15-50 race blend stuff and that seemed to come out clean, no noises etc... I'm looking into Joe Gibbs, Brad Penn and now the ULX110 stuff Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545110 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 8m 14d Gender: Male Posted 19/05/15 01:37 AM Share Posted 19/05/15 01:37 AM On 19/05/2015 at 1:32 AM, Peppy_t92 said: Ford recommend a Mineral 15w-40 oil for std applications, speaking with dad he seems to think that synthetic oils aren't the best for roller rocker applications as it tends to cause the roller to slide or rub rather then roll... Then again the coyotes and 5,4's also run roller rockers yet full synthetic is recommended for them, so I really don't know the theory behind it... But after the wear on my cams I'm willing to try something different just for my own research purposes.. I was using Nulon 15-50 race blend stuff and that seemed to come out clean, no noises etc...I'm looking into Joe Gibbs, Brad Penn and now the ULX110 stuffAll good Joe, was just curious.Brad Penn is good stuff, also heard good things about ULX Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/32/#findComment-1545113 Share on other sites More sharing options...
