  • Member For: 22y 30d
At all cost engine and box in one if possible. Done it dozens of times but never on an BA-FG. I have a winder bar on the hoist that allows me to get the tilt on the engine and box and also to level it. You can buy cheap chinese ones and I did try one but they are flimsy and would not recommend them. I built my own. But then you got to set it up on the hoist so that on full tilt you have enough verticle chain so the front top of the engine does not foul the arm on the hoist. (does that make sense) and that you dont have too much chain that you cant get the engine high enough over the front of the car. Try to set it up first with the chains where they should be than just hope for the best.
When the engine is tilted I usually set it up so I need to lift the end of the box into the engine bay a little.
Then you decided how much you got to lift the rear and sometimes even the front.
I guess a pit would help.
  • Member For: 12y 27d
It's been a long couple of days, didn't get as far as I would of hoped but we are well underway! I didn't get a chance to take pictures of every step but I have a few..
I picked up the motor on Thursday or Friday, done all the usual checks, gave everything a final wash and started assembly.. What a difference the line bore made, it wasn't "hard" to spin before, but this just glides now, so it probably even picked up a few hp haha..
I used a Stretch gauge to torque the big ends
The windage tray was almost pointless with the new girdle as it was about 0.7" away from the crank... So as screw driver and some improvisation goes a long way, bringing it closer to the crank, leaving about 0.15-0.2" away from the highest/lowest spots which is the big end bolts..
Dad touched up a few areas on the oil pump to help improve flow, and shimmed up the regulator spring about 0.1"
Now, obviously with the thicker girdle, the pickup is sitting closer to the sump.. Some measurements and moulding clay came up with the closest it could be was 0.25", we currently had 0.15"... So I cut down the bracket and re-welded it in its position about 0.3" from the sump..
The head went together somewhere in between.. All the spring seat heights were measured and came up with no need for shims, and I re-checked the spring tensions all coming up within a couple of lb of each other at closed and full lift...
The crow Race spring and retainer kit which was previously on it has known issues of the rocker touching the retainer, so some slight modification of the rockers was needed..
Isn't that a sexy look!
Everything was going very smoothly from all the previous measurements and checks...
Until...
We overlooked the timing cover, obviously with alot of meat coming off the deck and the head it's all sitting lower and the timing cover stays where it was
It was about 0.05" too high, the rocket cover gasket can't really take that up, and while we've done everything else properly I wasn't gonna skimp out on this..
I managed to get in contact with a local guy that has a CNC Mill in his garage haha... So he was able to machine it for me on Sunday...
It was a long process because his machine wasn't tall enough to stand the cover up, we had to lay it down and run a fly cutter along it a couple of times... But it came up with a great finish and at the right height...
Some final internal checks, and the sump and timing cover went on, then started adding pieces as I went
I may be modest, but she looks farking angry!!
I'll be trying to get it in tonight/tomorrow, get it started then I've taken some time off work, so I will have a good few days to get it run in, check everything then re-check to make it to Powerplay on Sunday!!
Thanks guys
Edited by Peppy_t92
  • Like 6
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 20d
you're right, that block looks sexy :) Also - how lucky to have a guy you know with a CNC mill available to use on a Sunday :wwww::dancing:
Actually I found him on Facebook, I posted on a Popular Page full of car enthusiasts and within 10mins a friend of his contacted me... But yea he will be a handy person to know from now on...
Dad loved it, I suspect we may invest in one eventually
