Peppy's Build Thread
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 7m 12d
Thanks guys,
the coating isn't very think at all, it's between 0.001-0.0015"
It looks thicker at the moment, but it still needs to be rubbed back
cheers - it did look like it needed rubbing down :)
  • Member For: 11y 7m 19d
Alright so after discussing with dad and the ceramic coater im happy to live with the 0.2hp loss on each cylinder form the little parts of the chamber that didn't get coated, but definitely a reminder for next time
This afternoon consisted of filling the block, what a long and painful process, I moulded the water pump area with clay, creating a passage to the level we decided to fill it to (67mm bellow deck, 3/4 up on the welsh plugs) I believe the area behind the pump is quite important in the water flow through the block...
It was hard to get photos, but you get the jist of it,
The instructions say 1-1.2l of water per 12lb bag, there's no way that was going to fit into the water jackets, so we added water to get a nicer texture, then started to fill each hole little by little, with me smacking the block for half an hour with a soft hammer, safe to say that it got through to every nook and cranny haha..
8e4837ae69a22d99139ff3d3faad68af.jpg before
e7f652b36268498e92de1904c7664a19.jpg after
It barley even took half a bag, so possibly about 1.5-2l worth, which I'm happy with but only time will tell how it goes in the cooling department.. It is a street car after all
When cleaning up I remembered reading that they actually add cast iron shavings to the mix, well they sure do,
bd76b695d5dcb9079020c3d8aa7cbac6.jpg that was just sticking the magnet into the bucket while cleaning up., I also noticed it was actually sticking to the walls of the bucket, so it's a type of concrete, glue, cast iron mix... I put the leftover in a plastic bag, so it will be interesting to see how it sets
Input shaft is on its way, and just waiting for the Alloy pan to be made, then the last big purchase is the injectors... The time and money this project is taking is starting to get to me, I'm a stress head so I'm trying to keep my goals clear to myself and stay positive... I just can't wait to see all our hard work come to life...
Haha but even then I still have the task of tuning it and learning the beauty of the ZF calibration... Then the tail shaft, diff, cv's are pretty much the last untouched parts, and surely they won't last long... I guess I'm realising how big of a commitment something like this is, physically, mentally and financially, so my respect goes out to anyone else that has done it
Thanks Joe
Ohh and I'm looking into a spark booster, I like the Kenne bell Boost A Spark, but still waiting for some reply's, Herrod are the only ones that have gotten back to me
  • Member For: 17y 1d
Ralph is the man with a kenne bell boost a spark installed, even a thread on it somewhere
How do you go fishing out the clay after the block filler sets ?
Edited by Wilko16
Yea I have already spoken to him about it just waiting to hear back from Kenne bell..
The clay will easily just come back out through the water pump opening
Okay, so it has been a busy week... We let the block fill set for a couple of days while washing and preparing everything else... Even after 24 hours the full in the bag wash rock solid
Looking into where the water pump is mounted,
Looking into the top of one of the water jackets
The passage we formed up with clay turned out good, it should help the water circulate without too much extra strain, we'll soon find out..
Cleaning is one of the most important parts when assembling anything, you have to be strict and don't be surprised if you end up washing something 4-5 times.. I lightly rubbed the Ceramic coated parts with scotch bright... They look very pretty now! Haha
Now it's time to finish off the block, so go over everything, get rid of the excess splatter on the side walls of the water jackets from when we poured the filler, smoothen all the oil returns with the die grinder and basically just check if we have overlooked anything.. Then wash it, run a stone on any flat surface or sharp edge, get into every oil and water passage then give it a soapy bath, and blow dry with air while spraying it with WD40.. Also wash the crank, main caps, bearings, stids, girdle, windage tray... And once their washed keep them covered until assembly then wipe again before you use them..
It should all come together by the end of the week, I still trying not to rush, but powerplay is coming!!
Thanks, Joe
  • Like 2
  • Member For: 18y 11m 4d
Comming along nicely Joe, Love the attention to detail and quality writeup.
