JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 6d Gender: Male Location: Adelaide Posted 13/04/15 05:03 AM Share Posted 13/04/15 05:03 AM 47 or GTFO lol Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1539617 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 2m 3d Gender: Male Location: Central Coast Posted 13/04/15 05:03 AM Share Posted 13/04/15 05:03 AM Gtx55 or go home Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1539618 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 3m 5d Gender: Male Location: Liverpool Posted 13/04/15 05:09 AM Author Share Posted 13/04/15 05:09 AM Done!! next year, I'm also liking the cage that's in jet066 subtle yet effective haha Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1539619 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 12y 6d Gender: Male Posted 13/04/15 12:22 PM Share Posted 13/04/15 12:22 PM Awesome thread. Love the fact you're doing this yourselves. Big totes peppyAs much as I'm enjoying this build for the moment, I'd love to see some gearbox stuff. I'm thinking I could give that a go as my next big learning curve 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1539680 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 1m 12d Gender: Male Location: Central Queensland Posted 17/04/15 03:28 PM Share Posted 17/04/15 03:28 PM (edited) We cut up a cylinder head, so that we could better understand the port and how much meat there was around the water jackets. It was quite interesting.... Edited 17/04/15 03:35 PM by HI PSI Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1540268 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 3m 5d Gender: Male Location: Liverpool Posted 18/04/15 08:56 PM Author Share Posted 18/04/15 08:56 PM We cut up a cylinder head, so that we could better understand the port and how much meat there was around the water jackets. It was quite interesting....That was what we wanted to do but instead drilled numerous holes to measure the walls in different spots, Then made a mould to measure cross sectional areas etc Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1540416 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 3m 5d Gender: Male Location: Liverpool Posted 18/04/15 09:19 PM Author Share Posted 18/04/15 09:19 PM Alright so we're moving forward, the head and motor are back...The head was milled, seats were cut and the valve guides were cut/drilled down.. Now it still has to be sent away for ceramic coating of the chamber, valves and exhaust ports, then it will be dummy assembled to measure the valve heights and valve lash then the valves may have to each be "tipped" (ground down) to achieve the same heights and lash, that will help with lifter pump up and keep everything efficient..I cc'd the chamber and the ports to get some accurate cross sectional areas and compression ratio for my program.The motor was decked and everything else was balanced.. I opted for "fire rings" to be installed, it's diesel technology, a brass ring is inserted into a ring machined into the deck then a copper gasket is used, Everything balanced up fine, except one piston was 1.5g heavy and the Atomic ring gear was quite far out,You'll see a few extra holes drilled outNow time to prep the block, get rid of any sharp edges left from the machining, stone all the flat surfaces, check all the oil gallies, clean out the welsh plug holes and give it a wash... We have now decided to grout fill the block about half way up the welsh plugs, this will give the bores the strength they need to withstand it's punishment, and if done correctly it shouldn't effect coolingI'm still waiting for parts for the ZF, I have ordered the Nizpro stage 2 shaft, and their Street level billet alloy Pan, which will help with cooling and holds 2l extra oil, a set of exedy 1000hp clutches and a Sonnax Zip Kit for the valve bodyEnjoy 3 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1540418 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 6d Gender: Male Location: Adelaide Posted 18/04/15 10:57 PM Share Posted 18/04/15 10:57 PM Head looks good joeHow much came off the head to deck it "true" looks like a bit came off Looks like the comp is getting up there now Have u calculated a final figure ?Bit of a shock the aromic flex is out, was it anywhere near in balance ? I mean of course they would balance it but did you take it just closer to bang on ?Do you think ull get much crush on that copper/ring when torqued up ? Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1540430 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 19y 1m 12d Gender: Male Location: Central Queensland Posted 18/04/15 11:06 PM Share Posted 18/04/15 11:06 PM (edited) I had considered using a Cometic Phusion gasket in my build, but I ended up installing a factory gasket, as we felt that they provided the best reliability and seal. What advantages do the fire rings have over other gasket styles?Did you end up going to a bigger valve, or retaining the standard spec? Edited 18/04/15 11:07 PM by HI PSI Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1540431 Share on other sites More sharing options...
Peppy_t92 Silver Donating Members 748 Member For: 12y 3m 5d Gender: Male Location: Liverpool Posted 19/04/15 04:58 AM Author Share Posted 19/04/15 04:58 AM Originally I was going to 0 deck the block (0.038" bellow @tdc), just shave the head and a 0.01" gasket, which is the most you would go if your thinking about bigger cams in the future... But now with the copper gasket its 0.04" so I took 0.04" off the block and 0.04" off the head to get me back to where I wanted, the comp is only going to be 9.0:1 the only way to get any more would be to go flat tops with valve reliefs cut out ... 0.04" off the head only brought the chamber volume down to 63cc..Yea It is, I'm in two minds about speaking to brad and asking what the go is, or at least notifying him, they had to dill a 12mm hole and a 19mm hole pretty much next to each other, so there would be a few grams in it..The brass is bang on 0.04 the gasket is 0.0395-0.04 so we're doing to seal around all the oil and water passages each side of the gasket, but no I don't think it will crush much at all..The main advantage is to seal the combustion space, as said they are generally found in diesel motors which run much higher cylinder pressures, so hopefully it keeps everything in.Nope std size valves are being used 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88860-peppys-build-thread/page/16/#findComment-1540482 Share on other sites More sharing options...
