polarbear Member 20 Member For: 11y 20d Posted 31/07/14 06:33 AM Share Posted 31/07/14 06:33 AM Got this steel braided turbo oil feeding line from eBay for my fg falcon. Did not really come with any fitting instructions. Can anyone please help give some fitting instructions for me. Do I removed the factory version and install this? Do I need add engine oil too since it may leak out some while fitting? Link to comment https://www.fordxr6turbo.com/forum/topic/88854-how-to-diy-fit-an-after-market-turbo-oil-line-in-fg/ Share on other sites More sharing options...
matsfgxr6turbo Member 388 Member For: 15y 4m 14d Posted 31/07/14 11:30 AM Share Posted 31/07/14 11:30 AM Yeah mate you may be out of luck I don't think theres any info on the site about fitting these good luck 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88854-how-to-diy-fit-an-after-market-turbo-oil-line-in-fg/#findComment-1488946 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 21d Gender: Male Location: WA, Perth Posted 31/07/14 11:37 AM Share Posted 31/07/14 11:37 AM On the AFF, there are instructions too.However if you use the search function, you would have found this pagehttp://www.fordxr6turbo.com/forum/topic/32461-turbo-oil-supply-screen-cleaning/The very first post has cleaning instructions. It may guide you as to what you need to do. Link to comment https://www.fordxr6turbo.com/forum/topic/88854-how-to-diy-fit-an-after-market-turbo-oil-line-in-fg/#findComment-1488948 Share on other sites More sharing options...
gregaust Member 48 Member For: 21y 9m 1d Gender: Male Location: QLD Posted 15/08/14 09:30 PM Share Posted 15/08/14 09:30 PM Pretty easy to fit. You won't lose any oil other than what's in the pipe. As a precaution just check level after. On FG usually long line goes on the turbo side then filter then short line to motor. On the motor side there is an outer nut that has the oil switch and retains the banjo. Undo it by holding the inner hex fitting so whole lot doesn't turn. Remove old steel line. Now inside the fitting on the block is a small circlip and a filter. If you're lucky with a little o'ring pick you might get it out, then hook the filter out. If not remove the fitting from the block and get it out. Now when refitting that back in the block, it will need a thread sealer and DO NOT OVERTIGHTEN or it can crack the block. Hook up the line to the new banjo fitting and refit outer nut + pressure switch. Test check for leaks. Link to comment https://www.fordxr6turbo.com/forum/topic/88854-how-to-diy-fit-an-after-market-turbo-oil-line-in-fg/#findComment-1492855 Share on other sites More sharing options...
