  • Member For: 16y 5m 16d
  On 31/07/2014 at 2:51 AM, Bonjaz said:
I had a mate run 400+kw with stock cross over years ago, on a hot QLD day going for a squirt it actually melted the hard plastic piping the goes from turbo to cross over. I wouldnt advise it...
^^^^ this was directed at a B series
  • 10 months later...
  • Member For: 11y 6m 14d
  On 01/08/2014 at 10:53 AM, GUN-808 said:
I wanted the exact same as u mate and wanted that stock look..
I ended up with the PW Street Airbox as mentioned above..
I love the look of my setup and was happy to sacrifice a few KW for the look I wanted..
Iv modded the PW unit to fit the stock OTR air intake.. Sik'ad a piece of silicone into the side with a hole cut into side panel..
On a "normal" QLD day the intake sits at about 29deg and iv seen it as low as 19 (it usually adds around 6deg from a few tests).. which I dont think is too bad.. im positive under normal driving it lowers the intake temps..
I cant comment on the pressure etc but I think its a good mod to do if your stuck on the crossover..
******** Update *******
Made 456KW with the crossover setup I mentioned here earlier so 450kw can be done easilly.. ran out of fuel pump so kept it at above figure for now..
Was only on 18psi too and yes with E85.. MTA750 Turbo..
  • Like 2
  • Member For: 20y 10m 2d
Nice result, got to be happy with that. No doubt power can be made with crossover, a turbo side just does it easier. I went from 400 to 450rwkw ditching the crossover. Feels like it spools quicker as well. The flip side is it makes heads turn whenever you step on it - not good when your after a stealth look
  On 02/07/2015 at 4:32 AM, bjc said:
Nice mine fellas! Almost a year old... :spoton:
I just put it up there for reference , just in case someone actually uses the search function before asking a question in a new thread :D lol
  • RNS10S
  • Member For: 18y 9m 7d
Mate of mine made 460 with a GTX3582R using herrod intake which has a very stock look, this is another option for the OP.
Car ran 10.4 @ 138.
http://i1145.photobucket.com/albums/o507/sk8xr8/g6eintake.jpg
Edited by rednose
Car ran 10.4 @ 138.
Rednose im hoping to be very close to those times next month.. :)
10.5 @ 135 has always been my goal with this car for what it is..
Wish me luck...
