daveyboii Member 29 Member For: 10y 11m 15d Posted 29/07/14 03:22 AM Share Posted 29/07/14 03:22 AM Hey guys,I feel like that I may be doing something wrong with blocking my bov as I feel that this topic would've been brought up before if it was an issue for many,in my FG xr6t ute I still have the stock bov and basically what I have done is blocked the vac hose that goes into the back of it with a bolt and put a short hose on the back of the bov with a bolt in that aswell to try get to flutter, but when I do this I feel like I lose a good 40kw or so Link to comment https://www.fordxr6turbo.com/forum/topic/88840-loss-of-power-when-disconnecting-stock-bov/ Share on other sites More sharing options...
Wilko16 Donating Members 1,672 Member For: 17y 5m 22d Gender: Male Location: Melbourne Posted 29/07/14 07:07 AM Share Posted 29/07/14 07:07 AM You just need a bolt in the little vac lineLeave the bov inlet and outlet connected like normal...If you think you have lost power it prob means you have disconnected something else Link to comment https://www.fordxr6turbo.com/forum/topic/88840-loss-of-power-when-disconnecting-stock-bov/#findComment-1488339 Share on other sites More sharing options...
Acefantasyxr6 Member 18 Member For: 10y 11m 4d Gender: Male Posted 29/07/14 11:21 AM Share Posted 29/07/14 11:21 AM I pulled the hose off the bov and put a bolt in the hose and left bov open and I reckon the same thing felt like more lag and less power and wasn't much of a dose. Mine doses as it is it just went for longer but wasn't as loud I wanna try a dose pipe and see how that sounds Link to comment https://www.fordxr6turbo.com/forum/topic/88840-loss-of-power-when-disconnecting-stock-bov/#findComment-1488404 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 9m 22d Posted 29/07/14 11:27 AM Share Posted 29/07/14 11:27 AM Wow . Your boost pressure is pushing the bov open. Usually the vacuum line is pressurised under boost which holds the bov shut. You need to remove the bov completely or stop it opening and also block the vacuum hose. Link to comment https://www.fordxr6turbo.com/forum/topic/88840-loss-of-power-when-disconnecting-stock-bov/#findComment-1488407 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 3d Gender: Male Location: Melbourne Posted 30/07/14 08:36 AM Share Posted 30/07/14 08:36 AM Block the vacuum line coming from the inlet manifold with a bolt... that's the simplest way to block off the BOV as it'll never see vacuum to open it. The ultimate way to block it off is remove it completely and put chair stoppers over both holes (clamped into position). Try the latter and see if that helps you. Link to comment https://www.fordxr6turbo.com/forum/topic/88840-loss-of-power-when-disconnecting-stock-bov/#findComment-1488634 Share on other sites More sharing options...
