  • Member For: 13y 4m 23d
Have a look at the nizpro site - On the exhaust side of things, they go a fair way with power increases without any changes, then a bit further with just a cat change.
  • 3 weeks later...
  • Member For: 12y 11m 10d
There is no definate answer because the exhaust becomes more of a restriction the higher amount of air you try push through it, the general consensus is after 300rwkw the FG exhaust should be upgraded so if your going a bigger turbo then you need an exhaust upgrade.
Edited by Z2TT
  • Member For: 13y 2m 27d
From my investigations for my own car they recommend changing the exhaust at around 320-330rwkw. Again, you could prob make more power than this without it but the back pressure on the turbine wheel becomes counter productive and pushes the turbo a bit too hard. Obviously when putting on a whole system, wastegates need porting to control boost due to the more free flowing nature of the larger exhaust.
  • Like 3
  • 2 months later...
  • Member For: 10y 11m 9d
its a hub centric dyno and ive taken 3 of my cars to the same tuner, hes quite reputable in melbourne motorsport scene, did 3 runs 2nd made just over 400 and then it was detuned to 385 or somethink due to running stock boost controller spiking
