  • Moar Powar Babeh
  • Member For: 19y 8m 15d
  On 16/05/2015 at 3:58 AM, gaz097 said:
Do you always act like a child or did I catch you on a bad day?
^this.... Reasonable question being asked yet you are persisting with the cryptic answers.
Either help him out or don't.
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 7d
Who's being a child ?
I told u to make an effort when u gave a dud response
Then I've made u actually think for a moment and you still don't like the answer.
I can't help you anymore, it's fairly simple do as u please I can't make people listen and iam not going to beat my head against the wall trying to help you if you cant keep up
Like I take anything personally so why would I get upset lol
Over the past few pages I've told you how to fix your issue
Over to you now .....
  • Bronze Donating Members
  • Member For: 13y 10m 17d
I'm struggling to see the difference between my curve and micks.
All I can do to limit problem is decrease cylinder pressure , ill still have a chat to my tuner and see the differences he tunes between stock engines and built engines and make a decision from there.
My initial thoughts are I can't add washers as my head is already compressed a little so I'll have to stick with the washers I have and go to a single gasket , as well as a little less timing and initial boost.
Lambda result is a cylinder pressure adder/subtractor
My complete point the whole way ?
  • MattyP
  • Cruise Control
  • Member For: 13y 1m 3d
This thread got out of hand real quick.
So what a gathered for an e85 tune dont go crazy on timing because of cylinder head pressure and keep a relatively lean AFR?
Which goes against everything you typically here with e85. I have just reached the limit of my setup
Timing can be whatever the engine can support it's the afr of e85 that can be leaned on and for obvious previous reasons
Many many 500+ cars running a different target lambda on E85 against their 98 tune
