gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 23d Posted 21/10/19 02:29 AM Author Share Posted 21/10/19 02:29 AM So I managed to snap a side diff bush bolt. What side diff bushes are the stiffest out there these days? And good value for money. Still can't believe the price of the cat600's. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689317 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 10d Gender: Male Location: Townsville Posted 21/10/19 03:43 AM Share Posted 21/10/19 03:43 AM On 01/10/2019 at 11:21 AM, gaz097 said: For those at home. Does not need to be linked. Swapped it out today with no issues Annoyingly just before swapping it the rpm tacho sprung back to life, so I still don't know if it's the cluster or something else How old is your battery Gazza? I ask as this can be an issue with the B series. Tacho not working, rear boot not popping, engine misfiring badly under load or poor idle...this is all funky $h!t that happens when the battery quality is bad.Yours could have been the connector though and when you were ferreting around to remove fascia or getting ready to it made a bad contact good again!?As for the diff bushes, don't they use superpro hybrids now? Me personally if you are chewing bushes out often then boat rollers are the go (hdpe) as its cheap and easy to lathe. Depending on where it's situated though it can be noisy...These? - https://superpro.com.au/find/superpro-diff-mount-bush-kit-for-a-superpro-suspension-parts-and-poly-bushings-for-ford-australia-falcon-2002-2008-ba-bf-sedan-/productnr-SPF3148PK/cid-999500234/vid- Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689319 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 17d Gender: Male Location: Perth Posted 21/10/19 07:58 AM Share Posted 21/10/19 07:58 AM Very very hard front bushes saves the rear. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689322 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 23d Posted 21/10/19 08:57 AM Author Share Posted 21/10/19 08:57 AM Battery is pretty good. Holds voltage well and cranks the car over quickly. It would only be 1-2 years old. It stopped again the other day momentarily. Once it's back on the road I'll out the other cluster in it and see if it fixes the issues. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689327 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 10d Gender: Male Location: Townsville Posted 23/10/19 12:22 AM Share Posted 23/10/19 12:22 AM So I watched this video this morning and yes they have the IMS diff hat but he's happy using Pedders front bushes. Haltech In saying that I use Pedders Nolathane throughout my F6X with no issues or flogging out... The front side bushes I did fill with Soudal T-Rex (polyurethane) as both times the mechanics installing them installed them incorrectly (how hard is it to follow a sheet with a picture?) and because these were for diff issues not bush issues I cbf...I have concluded though that after 3yrs Soudal is the king of bush void filling so will likely use it for EVERYTHING as I have done so far! Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689371 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 23d Posted 23/10/19 01:20 AM Author Share Posted 23/10/19 01:20 AM Is it better then the Sikaflex stuff? I filled the centre bearing back in the day and the vibrations were horrendous lol Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689372 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 10d Gender: Male Location: Townsville Posted 23/10/19 02:22 AM Share Posted 23/10/19 02:22 AM Probably not for noise and I'm surprised the sika actually made the noise any worse unless the bush was half flogged out! Soudal is definitely stronger and stiffer than sikaflex imo (the T-Rex version at least is because it's stupidly thick!). It won't stretch/give like sika does though but so far the stuff in the front bushes is still looking great and it's copped a spraying from the diff oil spewing it's guts and the CV's with no issues that I can see after I've degreased it to death! No difference in noise there on the front either but it could be a location thing also...I use a solid (custom 2 piece hdpe bush) in the 3rd bush location on the territory (drivers side front) and it made zero noise difference over the factory rubber. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689373 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 23d Posted 23/10/19 03:59 AM Author Share Posted 23/10/19 03:59 AM The bearing was brand new, I filled it with sika 252 I think, which dries like a 55 duro polyurethane. It's quite firm and rubber like.Sounds the same/similar as the dinosaur stuff. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689379 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 10d Gender: Male Location: Townsville Posted 23/10/19 04:13 AM Share Posted 23/10/19 04:13 AM Yeah totally different hardness and texture to the Soudal. I've got both in hardened form (and others) thanks to our "DeLux" climate up here so I just skin the sausage (sounds dirty) or strip the tube when they dry and cut cookies off them to use as packers under workbenches etc! Anything that vibrates...that's also dirty!!!Sika is more flexible. Like the rubber bonds are softer if that makes sense!? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689380 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 23d Posted 23/10/19 08:04 PM Author Share Posted 23/10/19 08:04 PM Got a pic of the tube you are using? Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/86/#findComment-1689396 Share on other sites More sharing options...
