NA_TURBO Member 532 Member For: 9y 8m 7d Gender: Male Location: Mildura Posted 07/09/19 08:19 PM Share Posted 07/09/19 08:19 PM Turbo seal, it's leaking oil into the exhaust housing. Does it mainly do it at idle? Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688191 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 11d Gender: Male Location: Townsville Posted 07/09/19 11:53 PM Share Posted 07/09/19 11:53 PM How'd you go@gaz097? Was it the turbo leaking? Not an oil pressure issue? (I assume you can log/monitor this) Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688195 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 25d Posted 08/09/19 03:15 AM Author Share Posted 08/09/19 03:15 AM No I can't monitor oil pressure The turbo is less then 2000 Kay's old, rebuilt by procharge so I would hope not. Its done it twice now, about every 10th drive. The last time it done it was I was driving casually home from work, and I noticed it when I pulled into the driveway. About a minute later it was all good no smoke at all. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688203 Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 8m 7d Gender: Male Location: Mildura Posted 08/09/19 04:19 AM Share Posted 08/09/19 04:19 AM Not sure what turbo you have, but with some you need an oil restrictor so it doesn't blow the seals. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688211 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 11m 16d Posted 08/09/19 05:04 AM Share Posted 08/09/19 05:04 AM How do you rate procharge? How legit are their claims that the 64mm will do 550rwkw and reach full boost at 3000rpm? Everything I've seen suggests it's laggier than a gen2 gtx3582. Figured you're the man to ask Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688212 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 19d Gender: Male Location: Perth Posted 08/09/19 05:50 AM Share Posted 08/09/19 05:50 AM On 26/08/2019 at 10:47 AM, OZYWALKER said: No Just no I mean if you want 1st to go 100+ and to cruise on 6th at 200. If your real keen get the GT ratio box. Longer first with the rest being closer ratio. Expand I get no grip until 4th,even 4th can spin. Just too much power through 3.73. Needs higher to grip. 2.73 would be perfect. Great for racewars to. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688214 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 25d Posted 08/09/19 07:21 AM Author Share Posted 08/09/19 07:21 AM On 08/09/2019 at 5:04 AM, Tom Tucker said: How do you rate procharge? How legit are their claims that the 64mm will do 550rwkw and reach full boost at 3000rpm? Everything I've seen suggests it's laggier than a gen2 gtx3582. Figured you're the man to ask It's laggier then a gen 1 GTX 3582. That's all I can compare to. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688219 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 4m 3d Gender: Male Location: SW Sydney Posted 08/09/19 10:12 AM Share Posted 08/09/19 10:12 AM On 08/09/2019 at 5:50 AM, arronm said: I get no grip until 4th,even 4th can spin. Just too much power through 3.73. Needs higher to grip. 2.73 would be perfect. Great for racewars to. Expand Would go 2 fitty for sure..... 3 1 Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688228 Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 8m 7d Gender: Male Location: Mildura Posted 10/09/19 10:55 AM Share Posted 10/09/19 10:55 AM Got it sorted out Gaz? Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688299 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 10m 25d Posted 10/09/19 11:21 AM Author Share Posted 10/09/19 11:21 AM Err I have driven it every day since with no issues. Didn't do anything though The turbo came back from procharge with a feed nipple in it. Looked about the right size. Link to comment https://www.fordxr6turbo.com/forum/topic/88767-gazzas-turbo-build/page/84/#findComment-1688300 Share on other sites More sharing options...
