  • Bronze Donating Members
  • Member For: 13y 9m 9d
Been razing around with the tr6060 in and it's so much nicer to drive with it.
Shifts about a million times better. Far less roll over noise. Completely different car to drive.
And the super low first gear gets it through intersections so quick. I quite like it.
Problem 1 though. Cruise control does not work in 5th gear. 3rd 4th 6th still does.
I think I may have solved my issue as I write this though. As it's gotta match rpm with wheel speed to know what gear it's in (also why you can't engage cruise in first and second) it can't make the connection as the ratios are different?
Tuning people. Is there a gear ratio adjustment that can be changed ?
Or possibly something else ?
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 20d
who sets cruise in 5th anyway? I never do... just 4th and 6th. 4th for up to 60, anything higher than 60 and I use 6th :idunno:
  • Member For: 21y 7m 26d
Isn't cruise control over 40km/h regardless of gear? Can't really remember anymore what gear (thought it was 2nd for wow factor!) I used to drive around the base in with the 04 blown xr8 with the 5sp at 40k's with cruise control enabled...or I may have been speeding!?
Have a intermittent oil smoke problem. Only there occasionally but when it does it's like the photo below. After this photo was taken it cleared up about 2 minutes of ideling later.
Not there on cold starts, and valve stem seals were done at engine rebuild time so have done 30k Kay's.
Compression test came back 165psi pretty damn even across all cylinders.
Pcv and check valve seam good. Rattle and are free to move.
Any ideas? And yes it's definitely oil.
