  • Bronze Donating Members
  • Member For: 13y 10m 23d
There's one here on gumtree for 1200 asking price. Meant I have done 80,000 Kay's.
To rebuild mine I really should throw a input shaft at it, plus bearings, plus whatever gears are broken. Easily be over $1000.
  • XR50T
  • Member For: 12y 1m 12d
Magnum/GM shaft is a 1k job.
+ new gear and bearings if the rest hasn't been smashed by loose metal shards.
  • 2 weeks later...
Anyone know what would be required to fit a tr6060 in place of the t56?
According to acs the Xtreme clutch is the same as long as I swap the bell housing to the t56 one to keep the ring gear lined up.
Is cross member the same between BF and FG? 6a8a3d8f1450897e3407e389a2ecc6d2.jpg
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 3d
FG TR6060 has an offset shifter but can work as long as you get an FG shifter to go with it. I'm not sure about the crossmember.
  • XR50T
The tr6060 is slightly beefier looking but mounts up the same.
They're spot on about the bell housing. Keep the fg one if you want the option of using an fg clutch down the track.
$$$ may be cheaper, or you might want the bigger flywheel one day.
The shifters are basically the same and are swappable. The only difference is the b series bolts from shifter to stick go front to back where as the fg is left to right. Either way the shift stick/knob itself sits in the same spot.
  • XR50T
Yep
T56 fits on a t56 magnum.
Tr6060 fits on a t56 magnum.
That's what I found.
  • XR50T
Shifts nice, ratios are a bit too short for highway unless you want to be on boost.
Not bad, worth the dollars? I still don't know.
  • Member For: 19y 19d
  On 20/08/2019 at 10:57 AM, gaz097 said:
Cool was the magnum worth the squillions of dollars?
Expand
For peace of mind and knowing that it will take pretty much anything that you can throw at it.... Yes,  it is...
  • Like 2
