gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 14d Posted 23/05/19 09:45 PM Author Share Posted 23/05/19 09:45 PM Same numbers as I said Link to comment Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 4m 5d Posted 24/05/19 12:28 AM Share Posted 24/05/19 12:28 AM Mine manual with a 26" radial and 3.7 in my 9 inch was crossing at 6500rpm for 135mph you'll need to lift the limited as with your power you should be at close to 135. Also you will need to go 3-400 rpm above what you expect to cross the line at. Only other option you have is to fit a 28" tire which you will have to lift it and get a big hammer out to make fit and even then it will only just get you 135mph at 6000rpm which will still need the limiter raised Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 14d Posted 24/05/19 03:00 AM Author Share Posted 24/05/19 03:00 AM Yeah thanks. It's what I thought. I recon I can get a 235/60 (or 65) R17 from a territory under it without issues as I've had 275/35r20's under it without a sweat. Anyone run a territory tyre down the drags ? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 8d Gender: Male Location: Perth Posted 24/05/19 07:08 AM Share Posted 24/05/19 07:08 AM Change diff gears to 3.46. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 14d Posted 24/05/19 07:51 AM Author Share Posted 24/05/19 07:51 AM Ideal solution Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 14d Posted 24/05/19 10:56 AM Author Share Posted 24/05/19 10:56 AM 30" tyre ftw 2 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 14d Posted 05/06/19 10:41 AM Author Share Posted 05/06/19 10:41 AM Another day, another rear wheel bearing. Finally found/built the tool required to press the hub out of the bearing 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,192 Member For: 16y 9m 25d Gender: Male Location: Melbourne Posted 05/06/19 12:02 PM Share Posted 05/06/19 12:02 PM well done on making that pusher. it's a lot cheaper to buy the bearing and not the hub itself, so you've done well there. 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 14d Posted 15/06/19 10:38 AM Author Share Posted 15/06/19 10:38 AM 430 Kay's over yesterday and today. Smoked a set of tyres in the second session, then did another 5 sessions on my 20" tyres. Car never missed a beat. Built Ford tough. #BarralyfPowercruise was absolutely mint today. Did 7 sessions, could have done more, and it flowed real well. Highly recommend 3 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,192 Member For: 16y 9m 25d Gender: Male Location: Melbourne Posted 15/06/19 10:41 AM Share Posted 15/06/19 10:41 AM nice work, big fella smash them tyres looking forward to when you show the videos 1 Link to comment Share on other sites More sharing options...
