Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 11d Gender: Male Location: South Australia Posted 06/03/19 06:44 AM Share Posted 06/03/19 06:44 AM Maybe the lifters are pumping up. Same result as soft valve springs but different thing happening. Link to comment Share on other sites More sharing options...
tazzanz Donating Members 573 Member For: 9y 6m 9d Gender: Male Location: NZ Posted 06/03/19 07:18 AM Share Posted 06/03/19 07:18 AM Hows that xtreme ceramic clutch a couple of years on gaz? Been recommended one Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 19d Posted 06/03/19 08:07 AM Author Share Posted 06/03/19 08:07 AM It's been rebuilt once as I think it was worn out. Ceramic plates are not daily friendly. Is really grippy to start with but after some abuse the bite fades a little. I've never driven with a high end clutch so can't comment too much. Bang for buck it can handle the abuse I throw at it. But another 100kw and I think I'd smoke it pretty quick. What the running cost for vavle springs supplied and fitted ?? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,220 Member For: 16y 9m 30d Gender: Male Location: Melbourne Posted 06/03/19 08:12 AM Share Posted 06/03/19 08:12 AM around the $800 mark. 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 19d Posted 06/03/19 08:29 AM Author Share Posted 06/03/19 08:29 AM Figured it be around 4 hours labour. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 6d Gender: Male Location: Townsville Posted 06/03/19 10:58 AM Share Posted 06/03/19 10:58 AM It'll be your springs then as the only other thing that would be similar is Overboost but that doesn't recover until an engine shut down and restart. You haven't fitted a shift light at all either? So it's not $1k anymore for springs fitted!I bought the Crow springs off ebay so they'll go on the pile heap of other bits I've got waiting for the Terry..... Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 11d Gender: Male Location: South Australia Posted 06/03/19 11:04 AM Share Posted 06/03/19 11:04 AM I thought the car already had springs done for some reason. 2 minutes ago, bjc said: It'll be your springs then as the only other thing that would be similar is Overboost but that doesn't recover until an engine shut down and restart. Pumped up lifters will do that too which is why I mentioned it before. Anti pump up lifters will help with soft springs, with regard to rpm. Overboost cutout will recover straight away. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 6d Gender: Male Location: Townsville Posted 06/03/19 11:10 AM Share Posted 06/03/19 11:10 AM How often does that happen though apart from when fitting new springs?Overboost on my xr6t used to require a restart before the throttle worked again (like a dead TPS otherwise). That was with a piggyback ecu though. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 11d Gender: Male Location: South Australia Posted 06/03/19 11:33 AM Share Posted 06/03/19 11:33 AM 4 hours ago, gaz097 said: if I keep it on boost for any period of time it breaks down, then when I return to idle it runs like sh*t. Clears up after a few seconds This is classic pumped up lifter symptoms. Soft aka stock springs will do that. If you have already replaced the springs and it's still doing it, the lifters are the next thing that will prevent the valves from closing. That aside, maybe the mixture is too rich, maybe the plugs aren't playing ball, maybe the coils suck, maybe something else is happening. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 11d Gender: Male Location: South Australia Posted 06/03/19 11:46 AM Share Posted 06/03/19 11:46 AM Also you can pull the springs out and test them to confirm if they are still good. Titanium retainers should be on the list if they aren't already installed. Link to comment Share on other sites More sharing options...
