  • Bronze Donating Members
  • Member For: 13y 6m 20d
Right new theory, as my stutter/misfire is quite inconsistent now and only happens at certain times.
Only does it when it's hot. Like proper giving it a hard time.
So either A.
Heat soak. Probably quite likely.
Or B. Fuel Cavitation when the second fuel pump kicks in. The reason I say this is the Hobbs switch I had here has a minimum setting of 10psi (and I have it set to 12), which is around when this stutter occurs.
Or C. Coils are still I <3 Bananased and get worse when it gets hot.
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 30d
it could be because the switch and extra fuel pump are taking more current from the system and your spark is suffering? :idunno:
  • Puff
  • Member For: 10y 11d
Run the second pump all the time or set it to come on at a couple of pounds so you can diagnose that part of it. What keefy said can be taken into account here too.
Get a giant single so you don't melt the motor if the second one fails.
  • Is on holiday from communism
  • Member For: 6y 1m 7d
  • Gender: Female
Get a better alternator and battery.
Problem solved
Trust me, I'm European.
Edited by I love kittens
