  • Bronze Donating Members
  • Member For: 13y 5m 5d
Lifting heads and E85 has been around for years
Have a think what u could change to suit
It all begins with the fuel
Lifting a head is all to do with cylinder pressure. The only thing I can change is target an initial lower boost to keep my af flat through the curve.
If that's the case , it's going straight on gumtree as there boring as f*ck to drive like that.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 6m 25d
Correct
Time for a re tune
People have managed 40psi on stock head gasket with e85
Edited by Wombat Bellend
Yeah all well and good to make a pretty power figure at the top of your rpm range but if you want a quick car on the street you need boost down low or you are going to get walked but a much lower kw car.
Speaking to my tuner earlier today and he always uses 14mm head studs. I guess this is the edge you play when you build stuff yourself.
  • loitering with intent
  • Member For: 21y 4m 7d
still get walked if it comes on too hard to early. Mid 300s tractable rwkw is adequate for a daily IMO. Decent compromise
Edit . Soft, B4 U lot start
Edited by Buf-Phoon
Gaz
With the basics you can smack boost in as hard as it can make it, I don't see the issue when tuned correctly
